Pulls to the right in 4 wheel drive only - Ford Truck Enthusiasts Forums
Old 05-27-2011, 12:16 PM
49er_rs 49er_rs is offline
49er_rs is starting off with a positive reputation.
My '02 F150 Screw started pulling hard to the right in the snow this past winter.
In 2WD it runs straight, only pulls right when in 4WD.
1.Vacuum seem to work fine. Actuator moves in and out about a 1/4" or so. (not sure how much it should move)
2. Raised front off the ground and tires spin in opposite directions. Turned steering wheel sharply both ways and wheels still spin opposing each other.
I've done a lot of searching and reading.
Any trouble shooting help or advice would be much appreciated.
Thanks.
Old 05-27-2011, 02:50 PM
brokenleg brokenleg is offline
brokenleg has a good reputation on FTE.brokenleg has a good reputation on FTE.
Kinda makes me wonder about that actuator.................
Old 06-03-2011, 09:42 AM
Can the actuator be removed and tested without destroying it?
Does anyone know approximately how much the actuator shaft should move?
Thanks.
A4wd versus AWD versus 4wd FarmLaw Expedition & Navigator 35 06-27-2016 11:07 PM
Popping & clicking noise in front end jeepfix Expedition & Navigator 6 08-22-2015 10:18 AM
Too much wheel spin=no traction 2012 SD Snowbuster 1999 to 2016 Super Duty 18 01-14-2015 04:08 AM
03 F350 4x4 Troubleshooting - Hubs Locked - Problem Resolved! Brett W 55 Ford 1999 to 2016 Super Duty 15 03-03-2012 05:52 PM
4wd system Butl85 2009 - 2014 F150 8 12-26-2011 08:17 PM
Tags
2004, 4wd, 97, bronco, drive, expidition, explorer, f150, ford, iowa, pulling, pulls, supercrew, wheel, wheels
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
