Spark Plugs for 390 - Ford Truck Enthusiasts Forums
Spark Plugs for 390
Old 05-27-2011, 12:50 AM
Greenford100 Greenford100 is offline
Greenford100 is starting off with a positive reputation.
Spark Plugs for 390
Thanks everyone for the news about the air filter, but now since I heard that NGK would be a waste of money, what do you guys suggest are the best spark plugs to build up a racing truck? I want ones that would be good for horse power.
Old 05-27-2011, 01:30 AM
Sleepy445FE's Avatar
Sleepy445FE Sleepy445FE is offline
Sleepy445FE is gaining momentum as a positive member of FTE.Sleepy445FE is gaining momentum as a positive member of FTE.
What ignition system are you going to be running? What heads? CR?
Old 05-27-2011, 10:58 AM
69cj's Avatar
69cj 69cj is offline
69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future
I've never had a problem with good ole Champions or Motorcraft. Wouldn't run AC's if they were given to me. Had too many failures with them.
Old 05-29-2011, 11:58 AM
Ford428CJ's Avatar
Ford428CJ Ford428CJ is offline
Ford428CJ is starting off with a positive reputation.
Like I said, If you run a Hyfire Box.... NGK's work very well and you have a wider variety of heat ranges to chose from. I wouldn't say that they are junk, its all in your set-up/ combo of parts used!
Old 05-30-2011, 12:38 AM
Bear 45/70's Avatar
Bear 45/70 Bear 45/70 is offline
Bear 45/70 has a good reputation on FTE.Bear 45/70 has a good reputation on FTE.Bear 45/70 has a good reputation on FTE.
Quote:
Sure but they will not improve anything which makes them a waste of money.
Old 05-30-2011, 03:59 PM
Ford428CJ's Avatar
Quote:
Not true and here is why. I love Autolites but then I decided to play around with different brands of plugs (AC, Champions and so on). I found that the NGK's would last 3x as long when compared to Autolites! They may not improve your performance but spark plug life! Worth the extra $ to do it. JMHO
Old 05-30-2011, 06:33 PM
Bear 45/70's Avatar
Yep, last 3X as long and cost 5X as much. That is poor business where I com from. I've probably installed in the neighborhood of 10,000 NGK plug and dollar for dollar I will stay with the Champions (with which I set 3 speed records and won 2 National Championships and was not sponsored by them either).
Old 05-30-2011, 09:21 PM
Ford428CJ's Avatar
They dont cost 5x as much. You may not like them and thats fine. Try a $1.58 for NGK plugs and $1.49 for Autolites. WOW $.09 more a plug!
NGK AP8FS 18mm x 1" Hex Projected Tip Spark Plug Stock# 2227
Autolite 124 Copper Core Spark Plug
Old 05-30-2011, 10:15 PM
Bear 45/70's Avatar
If you are talkin' the standard NGK plugs, I call on them lasting longer.
Old 05-30-2011, 10:40 PM
Ford428CJ's Avatar
They do! Been there and done that!
Old 05-30-2011, 11:14 PM
Bear 45/70's Avatar
I've put thousands of NGK plug in Ford and Chebby engines and never one had them last longer than the AC's, Champion's or Motorcraft/Autolite.
Old 05-30-2011, 11:32 PM
Ford428CJ's Avatar
I don't disagree with ya for the most part BUT with a Hyfire Box on an FE... NGK's are hard to beat. Otherwise, if your not running a Hot ignition (Hyfire Box on an FE)... The others work better then the NGK's do. JMHO
Old 05-30-2011, 11:37 PM
Ford428CJ's Avatar
Also the added bonus is, they have a wider heat range of plugs to play with and the other brands for 18mm dont! Unless you run aftermarket heads with 14mm is a different story all together.... JMHO
Old 05-30-2011, 11:40 PM
Bear 45/70's Avatar
Even in my race 428CJ I never had to run anything colder than a Champion F9Y. So that is not a plus for a street machine.
Old 05-30-2011, 11:45 PM
Ford428CJ's Avatar
I tried the NGK's AP9FS on my 11to1 Solid Roller 428 as a daily driver... A little too cold, so I jumped up to the AP8FS and it was much happier with that! LOL
f150 for a 5.4 spark plugs doughogan 2009 - 2014 F150 4 10-11-2016 03:29 PM
spark plugs for a 93 f250 5.8 waylen89 1987 - 1996 F150 & Larger F-Series Trucks 1 01-23-2016 06:35 PM
resistance in spark plugs??????????? manning-2 Electrical Systems/Wiring 1 08-15-2013 07:33 AM
spark plug washer someday General Automotive Discussion 3 09-19-2010 10:09 PM
Spark plug melted? dcpump 2004 - 2008 F150 4 01-20-2010 03:02 PM
Tags
1966, 1972, 390, adams, brand, fe, ford, motor, ngk, plug, plugs, racing, spark, sparkplugs, sponsorship, wes
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
