Caster/Camber bushings,, How to adjust?? - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Old 05-26-2011, 11:05 PM
Dutter's Avatar
Dutter Dutter is offline
Dutter is starting off with a positive reputation.
So i got the new ones is to level out my tires from my lift, and ill always think i have them adjusted right but then once i drive it, theyll go off again. And i know the TTB will angel the wheels when you lift it with a jack. But i left it on the ground and used a level on the rim to get it close and it was untell i drive it,,, So im out of ideas, What the book way or dos someone have a nice trick to do it
Old 05-28-2011, 07:54 PM
FireMe FireMe is offline
FireMe has a very good reputation on FTE.FireMe has a very good reputation on FTE.FireMe has a very good reputation on FTE.FireMe has a very good reputation on FTE.
You have to use an alignment machine, on an alignment rack, at an alignment shop. This is not something you do at home.
Old 05-28-2011, 10:27 PM
Dutter's Avatar
Yeah well i dont got the money, $60 may not be mutch but for me thats more then i got, But i was able to get one wheel perfectly level, After i drove it the bubble was between the lines, and my other one is getting close
Old 05-30-2011, 07:30 PM
greenpus greenpus is offline
greenpus is starting off with a positive reputation.
Quote:
seriously? you put all that **** on your truck to lift it and big tires and you don't have $60 for alignment? Maybe you should change your priorities in life...
Old 05-30-2011, 09:55 PM
Dutter's Avatar
Back off, I got them tire for free from my brother and put them on my self, My lift i made from scrap metal, my bumpers were also made with scrap metal that i built. So all of this cost me just about nothing but a lot of time work
Old 06-01-2011, 08:45 AM
wp120470's Avatar
wp120470 wp120470 is offline
wp120470 is a splendid one to beholdwp120470 is a splendid one to beholdwp120470 is a splendid one to beholdwp120470 is a splendid one to beholdwp120470 is a splendid one to beholdwp120470 is a splendid one to behold
Hang in there dutter. Sometimes its harder the older you get to remember the excitement of being 17 and fixin up your ride, and todays teenagers just point and daddy pays for a new one. 20 years from now they will be bringing things to you for repair. That is when you get to sit back and laugh about all the little comments you have to hear when you are not afraid of getting dirty. Just remember them when you add up the labor cost. I know from experience nothing you earn comes easy.
Old 06-01-2011, 10:05 AM
Dutter's Avatar
haha yep,, and Thanks, yeah it drives me crazy seeing them rich kids with big pretty trucks or nice car, and they MAYBE paid for the tires if that, thats why i call them daddies truck, but its ok my truck can out wheel them
Old 06-01-2011, 11:02 AM
grandmas77f150's Avatar
grandmas77f150 grandmas77f150 is offline
grandmas77f150 is gaining momentum as a positive member of FTE.
20 years from now you will also probably look back at your Ranger and laugh at the lengths you went to avoid opening your wallet.
I remember being your age (even though I'm only in my 20's) and wanting to mod my truck but couldn't afford it. That's why I got a job
Old 06-01-2011, 02:24 PM
michigan66's Avatar
michigan66 michigan66 is offline
michigan66 is gaining momentum as a positive member of FTE.
But in spite of all of those encouraging thoughts, you still need a professional alignment. Sometimes we have to bite the bullet on things like this.
Old 06-01-2011, 03:02 PM
Dutter's Avatar
yep im still looking for a job, iv applied at 8 other places and i know i can work, but iv goten no bites, because i got to save $970 for new 35s and then get my truck aligned, because if im goin to spend that much on new tires i want them to last
Old 06-01-2011, 07:25 PM
Bullitt390's Avatar
Bullitt390 Bullitt390 is offline
Certified Thread Hijacker
Bullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant future
So you're driving it straight and parking it and THEN measuring the alignment or lifting the wheel and setting it down and then measuring?
If you drive straight a short distance and measure that is your alignment specs then.
You also need something that gives an actual readout and not a bubble level.
Josh
Old 06-01-2011, 08:48 PM
Dutter's Avatar
well yes a bubble lever will tell u if the wheel is vertical its not like i can get it
%100 dead on but really close. but now i found out that when i adjust that it also effects my toe in and out, but when i adjust that it will effect my camber, so im just goin to have to mess with it untell i get a alignment
Old 01-02-2014, 01:04 AM
phawkins phawkins is offline
phawkins is starting off with a positive reputation.
i did the same thing with my level took some time but got it damn straight
Old 01-02-2014, 11:29 AM
g_k50 g_k50 is offline
g_k50 is gaining momentum as a positive member of FTE.g_k50 is gaining momentum as a positive member of FTE.
Yup, we haven't heard from Dutter since September of '12. I wonder if he's learned to spell yet.
Old 01-04-2014, 02:06 AM
Bullitt390's Avatar
Quote:
I believe he has a Superduty now and goes by a different name.
Josh
Is adjustable track bar needed? fordboy2 Excursion - King of SUVs 13 04-30-2016 07:48 AM
Camber Adjustment after Lift SoCal949 2009 - 2014 F150 1 05-04-2014 08:24 PM
2.5 inch front level Rudiak 1999 to 2016 Super Duty 10 03-19-2014 08:29 PM
Adjustable track bar/relocation bracket?? acf6 1999 to 2016 Super Duty 14 12-27-2011 02:08 PM
Lift vs Leveling Kit....a bit confused Sleepsafe 1999 to 2016 Super Duty 14 09-08-2009 10:55 PM
Tags
1996, 2006, 2008, adjust, bushing, bushings, camber, caster, castercamber, econoline, expedition, explorer, f150, ford, sport, trac
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
