Theft deterrent system
Low FOB battery voltage can cause it to act out. So if it hasn't been replaced in years, it may be time for a new one.
One of my then new, 99 Rangers FOB's began to act out, randomaly beeping the horn, or cycling the door locks as we drove. Reprogramming the FOB, keys, computer & new FOB battery didn't fix it, Dealer finally replaced the FOB, problem fixed. It had gotten wet sometime before the problems began & that probably led to it's demise. So if yours has gotten wet lately, try removing the battery & drying the FOB out at something like 120F overnight, reinstall the battery & see what happens.
Make sure the vehicle battery charge is up to snuff & the battery to engine & body ground connections are clean bright & tight.
More thoughts for consideration, let us know how it goes.
jeffsgrafx
03-26-2018 01:28 PM
cardc26
09-18-2012 05:04 PM
