Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1973 - 1979 F-100 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1973 - 1979 F-100 & Larger F-Series Trucks Discuss the Dentsides Ford Truck SPONSORED BY:
  #1 (permalink)
Old 05-26-2011, 03:28 PM
sportfuryjoe's Avatar
sportfuryjoe sportfuryjoe is offline
1976 Ford F-250
sportfuryjoe is starting off with a positive reputation.
Wiring dual fuel tanks to one gauge?
I'm having some troubles with my rear fuel tank (specifically the switch went bad), I bought a replacement but it's not working correctly.
So.... I'm planning to start from scratch and rewire the rear tank to the gauge. The in-cab tank works fine and reads on the gauge. But I'm unsure how to wire in a second tank to read on the same factory gauge.
Has anybody done this before? Can you help me out with a basic run down of the wiring diagram that you used? What type of toggle (on-on, on off?)
Any help would be greatly appreciated
  #2 (permalink)
Old 06-25-2012, 04:30 PM
johndee johndee is offline
Garage is empty, add now
johndee is starting off with a positive reputation.
fuel tank
sportfuryjoe just wanted to know if you got your tank wired in i am doing the same and also could use some help please let me know thanks john oh and your crew cab is sweet
  #3 (permalink)
Old 06-25-2012, 05:24 PM
mikeo0o0o0's Avatar
mikeo0o0o0 mikeo0o0o0 is online now
mikeo0o0o0 is a name known to allmikeo0o0o0 is a name known to allmikeo0o0o0 is a name known to allmikeo0o0o0 is a name known to allmikeo0o0o0 is a name known to allmikeo0o0o0 is a name known to all
Go here for the FACTORY wiring diagrams 1973-1979 Ford Truck Wiring Diagrams & Schematics - FORDification.net this should give you an idea of how it was wired from the factory.
  #4 (permalink)
Old 06-26-2012, 02:58 AM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Guru
2013 Ford Escape
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Quote:
Originally Posted by sportfuryjoe View Post
1976 F250: I'm having some troubles with my rear fuel tank (specifically the switch went bad), I bought a replacement but it's not working correctly.
There are two different: switches, fuel tank selector valves and wiring diagrams.
1973/74's have a manually operated fuel tank selector valve on the floor adjacent to the drivers side of the seat. All the switch does is change the dash fuel gauge from one tank to the other.
1975/79's have an electric fuel tank selector valve & solenoid assy (mounts on the frame rail). The switch changes the tanks and the fuel gauges.
1975/79: D5TZ-9A050-A .. Fuel Tank Switch / Available from Ford / MSRP: $35.29 / FTE sponsor tousleyfordparts.com price: $21.35.
1975/79:D5TZ-9189-B .. Fuel Tank Selector Valve & Solenoid Assy / Obsolete / No Ford Dealer or obsolete parts vendor has any.
__________________
Bill // Retired Ford Parts Manager // SoCal Chapter member // Part Number Research: 1928/2001 FoMoCo vehicles.
2013 Escape SE FWD 2.0L Eco-Boost.
  #5 (permalink)
Old 06-26-2012, 06:42 AM
KingBigJoe's Avatar
KingBigJoe KingBigJoe is offline
1978 Ford F-250
My Garage
KingBigJoe has a superb reputationKingBigJoe has a superb reputationKingBigJoe has a superb reputationKingBigJoe has a superb reputationKingBigJoe has a superb reputationKingBigJoe has a superb reputationKingBigJoe has a superb reputationKingBigJoe has a superb reputationKingBigJoe has a superb reputationKingBigJoe has a superb reputationKingBigJoe has a superb reputation
Subscribed for future reference.
__________________
Joseph - Leader of the FTE Indiana Chapter
Rustoleum: 1978 Ford F250 Ranger XLT 400/C6/NP205/Dana 44 Front/Dana 60 Rear. Looking for a 1986 to 1997 4x4 F350 for its axles, 460 (or 351W), & whatever tranny is behind it (except a C6).
People Carrier: 2000 Dodge Durango SLT 4x4 4.7 L - Power everything & it is all stock !
  #6 (permalink)
Old 06-30-2012, 08:02 PM
73supercamp 73supercamp is offline
73supercamp is starting off with a positive reputation.
switch??
i have a 73 SCS with dual tanks and i think the switch is bad. it is located next tto the climate control (opposite the fan switch) its part number is D3TB-9A050-AA. does anyone know where i can get one or what part number replaces this one?
  #7 (permalink)
Old 06-30-2012, 08:13 PM
mikeo0o0o0's Avatar
The p/n is D3TZ-9A050-A
Switch assy., fuel tank selector
D3TB-9A050-AA, 3 terminal
Unfortunately I couldn't locate any dealers or obsolete suppliers that had any.
  #8 (permalink)
Old 06-30-2012, 08:46 PM
does anyone know if it will cross over to another number by chance?
  #9 (permalink)
Old 07-01-2012, 10:29 AM
mikeo0o0o0's Avatar
Try Ford Parts - Genuine OEM Ford Auto Parts at FordPartsGiant . I've never heard of them before but I was doing a random search for the switch and came across this site.
According to the site they have the D3TZ-9A050-A switch, cost is $37.01
  #10 (permalink)
Old 07-01-2012, 12:10 PM
bamaf150's Avatar
bamaf150 bamaf150 is offline
bamaf150 is gaining momentum as a positive member of FTE.
Quote:
Before you replace it you may want to mess with it, heres what happened to me. Mine would not switch to the rear tank either, test light on the valve below the cab showed no juice. In the process of replacing the vacuum switch for the heat control behind the dash I had to unplug the selector switch for the tanks. After I plugged it back in I switched it and heard a click below the cab and the needle on the gauge moved, put the test light back on it and sure enough it was getting power now. I have been using the rear tank ever since.
__________________
1976 shortbed F-100 4x4
360 4 spd
http://http://i855.photobucket.com/albums/a...Fats/764x4.jpg
  #11 (permalink)
Old 07-02-2012, 10:10 AM
thanks
I did take it out and mess with it some. Once I hooked it back up it started working. Now all I have to do is find a sendng unit for the rear tank. It has a 25 gallon plastic tank. I can not find one anywhere but I was looking and wonder if a sending unit from a late sevetys bronco might be the same. Anyone have any ideas?
Tags
1978, 1979, dual, f250, ford, freestyle, fuel, gague, gas, gauge, gauges, swith, tank, tanks, wire, wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
