Compressor/ electric to gas conversion - Ford Truck Enthusiasts Forums
Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
Old 05-26-2011, 10:13 AM
SCRWDRVR's Avatar
SCRWDRVR SCRWDRVR is offline
"Obsessed"
SCRWDRVR has a great reputation on FTE.SCRWDRVR has a great reputation on FTE.SCRWDRVR has a great reputation on FTE.SCRWDRVR has a great reputation on FTE.SCRWDRVR has a great reputation on FTE.SCRWDRVR has a great reputation on FTE.
I have a compressor I purchased before I moved that was electric (220) and don't have enough power in my current garage to use it so I want to convert it to run on a gas engine, I'm figuring like a lawn mower engine or something like it. Anyone have any insight or experience with this conversion and what is needed?
Old 05-26-2011, 11:26 AM
tjc transport's Avatar
tjc transport tjc transport is online now
i ain't rite
tjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputation
a blowoff valve and high idle circuit.
other than that, it is just a matter of matching pulley sizes
Old 05-26-2011, 08:04 PM
SCRWDRVR's Avatar
"Obsessed"
I'm guessing the high idle circuit would kick the idle down when you get to top pressure....
Old 05-26-2011, 08:12 PM
Ford_Six's Avatar
Ford_Six Ford_Six is offline
Ford_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputation
Compressor heads that are designed to be run by a gas engine have unloaders that open the intake valves once the tank is full, at the same time the engine idles down. This prevents them from increasing the pressure in the tank once it's reached the set limit. Some use a centrifugal clutch on the engine to stop a standard compressor head once the engine idles down, but that isn't as common and getting the proper sized pulley for the engine can be a bit of a challenge.
To get the proper sized pulley, you will need to know the pulley size and maximum and minimum operating RPM for your compressor head, and the rated max RPM of the gas engine. This will help you calculate the pulley size for your engine. Do not go over the compressor's max rpm.
Old 05-27-2011, 01:02 AM
fixnair's Avatar
fixnair fixnair is offline
fixnair has a very good reputation on FTE.fixnair has a very good reputation on FTE.fixnair has a very good reputation on FTE.fixnair has a very good reputation on FTE.
You can get whats called a "discharge unloader" to control the compressors capacity. When the pilot valve signals the compressor to unload, it opens the discharge line to atmosphere and sends an air signal to the engine slow down device to slow the engine. A check valve keeps the compressed air in the tank and will not allow it to vent out the open discharge line.
When the pressure falls in the tank, the pilot valve closes, the engine speeds up and the discharge line is shunted back to the tank and the tank is pumped up again.
Now, the engine size can be approximated by doubling the horsepower of the electric motor. If you had a 5 horsepower electric motor then you will need at least a 10 horsepower gas engine.
Now you need to know what speed your compressor is turning. Dia. of motor pulley times motor RPM divided by compressor pulley dia will give you the compressor speed. ( d times comp. RPM devided by D where d=small pulley and D=large pulley.
Next you need to find out at what speed your engine will produce 10 horsepower. Using the above formula and changing it around a bit we come up with: D times Comp. RPM divided by eng RPM will give you the pulley size for the engine.
Hope it all makes sense to you. I can provide the parts if you need. I have attached some info you may find useful.
Old 05-27-2011, 05:40 AM
SCRWDRVR's Avatar
"Obsessed"
Thanks guys, it does get way confusing. What do the parts run for doing this?
Old 05-27-2011, 01:58 PM
fixnair's Avatar
Control devices should run you less than $75. Sheave & belts around $100.
Old 05-27-2011, 10:48 PM
*2fords* *2fords* is offline
*2fords* is gaining momentum as a positive member of FTE.
There was a compressor shop on Auburn Blvd. ( I don't remember the name of the place though) in Sacramento California, that new their S$*t. They helped me set up my on-baord on on my Jeep, and I haven't had a lick of trouble with it since they helped me.
Old 05-27-2011, 11:38 PM
Ford_Six's Avatar
You'd probably be best off getting a gas-powered wheelbarrow compressor and using your as an extra storage tank inline until you have the power to run it. That or sell it and replace with one that's already set up.
I got a wheelbarrow compressor off Craigslist with a 5.5hp Honda and three cylinder compressor head for $325. Those sort of deals are not that common to come across, but they are out there.
Old 05-28-2011, 01:41 AM
85e150six4mtod 85e150six4mtod is offline
85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation
IMO easier & cheaper to run wires for a 220v hook up.... ymmv.
Old 05-28-2011, 08:45 AM
SCRWDRVR's Avatar
"Obsessed"
Quote:
My garage is about 100 feet from the house and it will cost about $1000.00 to run it. I can buy a gas compressor for that.
Old 05-29-2011, 07:16 PM
How is it wired now, just 120v? No breaker box?
Old 05-29-2011, 09:46 PM
SCRWDRVR's Avatar
"Obsessed"
Its not wired here, I had it hooked up at my old home with 220v......
Old 05-30-2011, 12:42 AM
I meant the garage.... However, if you have 120v to the garage, you might be able to fit a 120v motor to the compressor. Reduced performance, but you retain the pressure switch and automatic on-off functions.
Old 05-30-2011, 10:49 PM
f4fran f4fran is offline
f4fran is starting off with a positive reputation.
How big is your compressor? I have an older Sears compressor (30 years old) that is currently wired for 220. A few wires can be switched around under the access plate and have it rewired for 120 volts. Of course it will draw double the amps at 120 than 220 volts. Do you know if yours can be rewired?
Fran
A/C compressor runs renchr56 1997 - 2003 F150 4 10-23-2015 08:09 PM
A/C Compressor greatbatchw 6.0L Power Stroke Diesel 4 07-21-2015 03:40 AM
Please help me with my custom A/C sittinlow88 1967 - 1972 F-100 & Larger F-Series Trucks 3 04-05-2015 11:41 PM
Replacing a york style compressor. 46Whizzer 1973 - 1979 F-100 & Larger F-Series Trucks 6 03-20-2015 11:36 AM
6.2 Autogas conversion RyCoy 6.2L V8 1 01-26-2014 12:43 AM
Tags
air, box, compressed, compressor, conversion, conversoin, converting, electric, elrctronic, engine, ford, gas, older, propane, trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
