Driving in 4A mode question - Ford Truck Enthusiasts Forums
2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
Old 05-26-2011, 02:24 AM
TCAS007's Avatar
TCAS007 TCAS007 is offline
TCAS007 is starting off with a positive reputation.
I am new to this forum and used the search already. It found me lots of information about the different 4WD modes but I did not find an answer to my question yet.
Well according to the manual you can use the 4A mode at any time, any surface dry or wet. I know that the 4WD should be used in slippery conditions only and not on tight curves but I tried the 4A out on a normal drive.
To me it seems it shifts pretty rough and there is some howling sound for a while after a curve and when starting. It's not all loud and does not sound like something broke but still weird as it should not go on 4WD under the conditions I tried it.
What are your experiences?
Eric
Old 05-26-2011, 07:13 AM
glruff's Avatar
glruff glruff is offline
glruff has a superb reputationglruff has a superb reputationglruff has a superb reputationglruff has a superb reputationglruff has a superb reputationglruff has a superb reputationglruff has a superb reputationglruff has a superb reputationglruff has a superb reputationglruff has a superb reputationglruff has a superb reputation
According to Ford,
Quote:
4A (AUTO): In this mode, electronic control four-wheel-drive power is delivered to all four wheels, as required, for increased traction. For all on-road conditions, including dry road surfaces, wet pavement, snow or gravel.
On my 2010 in 4A, I notice no real difference from 2H, unless the road requires the 4A to kick in because of loss of traction.
Old 05-26-2011, 07:30 AM
chuck s chuck s is offline
chuck s is starting off with a positive reputation.
I can feel the extra load on the engine switching from 2High into 4Auto.
Very slight but you should notice it if you set the cruise at (say) 35mph on a flat road and switch between the two modes. 2H gives better fuel economy due to less strain but that probably takes laboratory instruments to measure.
I run 2H all the time other than in the rain where it's easy enough to rotate the switch to 4Auto. I rarely use 4High except on very loose surfaces and only use 4Low to make sure it still works and occasionally when hooking up my camper as the truck crawls in that setting and I can hit the coupler easier.
My Explorer only has 4Auto, 4H, and 4L and has been running in 4Auto for 120,000 miles.
-- Chuck
Old 05-27-2011, 01:34 AM
TCAS007's Avatar
I agree with all you said. But did you heat that noise when in 4A and going through a curve? It starts in the curve and stops like 3 seconds after it. Kinda weird it happens even when no 4WD is required.
Old 05-27-2011, 07:15 AM
Probably the front/rear differential (?). I'll have to listen more closely. I don't recall any noise in my Explorer which I drove for 5 years before it went off to college with my daughter 4 years ago.
-- Chuck
Old 05-27-2011, 07:52 PM
glruff's Avatar
OK, just to test, I drove around all day in 4A. In town up to 25mph, left turns, right turns, with no noise. In a Lowes parking lot, made sharp left and right turns at about 15mph and no noise. All surfaces were hot and dry.
Also while in the parking lot, shifted into 4H made sharp left and right turns at less than 10mph, the noise it made sounded like the front wheels were grinding. This, I would guess, is because there was no give(slippage) while in 4wd. Shifted to 4A, noise gone. Shifted to 2H noise was gone.
Could you have an issue with your traction control system that is not allowing the 4A to operate as designed?
Old 05-29-2011, 01:02 AM
TCAS007's Avatar
Thank you so much for testing this! When I go to the dealer I will ask for someone to have a testdrive with me and they will have to explain it.
At higher speeds there is no noise noticable. Only at lower speeds like how you were testing.
I will keep you updated.
Thanks again!
2001 EB drive ability issues AZ_Hardwoods 1997-2006 Expedition & Navigator 3 07-24-2016 07:31 PM
MPG in 2-Hi vs 4-Auto dh_meyer 2009 - 2014 F150 10 01-14-2016 05:14 PM
4WD Not Working Rusty Axlerod 6.0L Power Stroke Diesel 30 11-05-2015 05:29 PM
ESOF and OEM Auto-Hub Operation agsmv1 Excursion - King of SUVs 4 06-04-2015 03:45 PM
87 to 96 f 150's with 6" lifts or know about driveshaft angles l67cooled 1987 - 1996 F150 & Larger F-Series Trucks 2 12-29-2009 05:53 PM
Tags
03, 2009, 2010, 4a, 4h, 4l, 4wd, conditions, dakota, drive, driven, expedition, ford, mode, north, pavement, powered, road, travel, vbulletin, wet, wheel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
