Broken exhaust manifold bolts. - Ford Truck Enthusiasts Forums
Old 05-25-2011, 10:42 PM
Stangfire Stangfire is offline
Stangfire is starting off with a positive reputation.
I've had a tick from my motor for a while. It's on the passenger side and much more noticeable when first starting the engine and it's cold.
I was under my truck tonight and noticed both exhaust manifold bolts on the passenger side very rear cylinder Going into the block are broken.
Would this cause an exhaust leak and make the ticking sound?
How do you fix the broken or missing studs/bolts?
Old 05-26-2011, 07:56 AM
Ultramagdan's Avatar
Ultramagdan Ultramagdan is offline
Ultramagdan has much to be proud ofUltramagdan has much to be proud ofUltramagdan has much to be proud ofUltramagdan has much to be proud ofUltramagdan has much to be proud ofUltramagdan has much to be proud ofUltramagdan has much to be proud ofUltramagdan has much to be proud ofUltramagdan has much to be proud of
Yes, it sure would.
There are a lot of post here about fixing this common issue. I recommend replacing all of the studs with new ones.
Old 05-26-2011, 01:58 PM
randy6800 randy6800 is offline
randy6800 is starting off with a positive reputation.
I just had this problem fixed on my 2000 F150 with the 5.4 engine last week. For the last 2 years I have put off fixing it myself and I found a local guy that fixed it for 125 dollars. I bought a new manifold from Rock Auto for a around 75 bucks and some stanless bolts on ebay for about 15 bucks. I got lucky finding somebody to fix it for that cheap and if you look around you may also. My manifold was rusted up bad also.
Old 05-27-2011, 07:24 AM
Looks like the two rear passenger bolts are broke off down inside. I can't see any meat from the studs at all.
I think I may have to take it in.
What's the worst case scenario?
Old 07-05-2011, 06:48 AM
paulywauly68 paulywauly68 is offline
paulywauly68 is starting off with a positive reputation.
get a drill with some good bits center punch them start drilling a little 45 degree air drill works good on slow rpms
Old 07-05-2011, 11:09 AM
Is there a trick to getting the center punch "centered"?
I know the two broken studs are snapped off about flush with the block so they for sure have to be drilled out. I'm worried all the others will snap off flush and I'll have to drill all of them out.
My biggest concern is snapping a drill bit off in the block.
Old 07-05-2011, 11:32 PM
Dave G. Dave G. is offline
Dave G. is gaining momentum as a positive member of FTE.
They seldom "break" off entirely flush with the head (not the block). The gaskets are a laminated steel, and once corrosion gets in the layers, you get a leak. You can't fit the new one in there anyway, without removing or at least loosening the manifold to pull it away from the head. You may as well replace all the studs, as Dan suggested, and all new gaskets.
The studs actually come out better than you would think, as they corroded off rather than broke off from too much torque. The biggest problem encountered is the bolts with the nuts still attached have corroded enough that they often end up a ******* size. I've routinely had to select a socket that is a fraction too small, and drive it on to remove the nut, or sometimes the nut and the stud.
The gaskets and studs/nuts from the dealer are fairly expensive ( and obviously they do not hold up). You can't go too far wrong by just picking up some grade 8 metric bolts/small washers, and aftermarket gaskets, like Felpro.
For easier access to some of the bolts, the inner fender may have to come out. You'll see why after spending a couple of hours on 1-2 bolts. I've always cut the down pipe bolts also, and just replaced them. Without doing that, moving the manifold around much will be limited.
Before you put the manifold back on, check it really well for hairline cracks.
Dave
Old 07-06-2011, 08:55 AM
Thanks for the advice. I think I'd buy a new manifold as mine is very rusty looking.
I don't mind drilling two of them out just hate to drill all 8 out.
Old 07-06-2011, 08:51 PM
I think I've replaced bolts/gaskets on maybe a dozen manifolds so far, and I'd say out of that many, I've only had to drill out approx. 6-8. Often as not, enough is hanging out when the manifold is off, that a small (5-6") Visegrips will twist them out. With the nuts corroded off, the torque on the threads is gone. Minor corrosion is all that usually holds the leftovers in the head.
If you get a new manifold, and NOT from Ford, it will likely be Chinese, so pick your poison.
Dave
Old 07-08-2011, 07:32 AM
BFTUFF BFTUFF is offline
BFTUFF is starting off with a positive reputation.
You can find metric stainless steel bolts at ACE hardware. I believe "Stage 8" makes a SS stud kit, call them and see if they still do? If replacing the exhaust manifolds, it would be wise to just install some JBA SS shorty headers instead of wasting money on stock exhaust manifolds.
When removing the rusted exhaust manifold, don't bother trying to use a socket wrench on the nuts. Just get out the die grinder and buzz them all off. You can then just pull off the old manifold and as stated above, use some penatrent and a vise grips to carefully remove them. If some or all break off, you'll have to drill them out slowly with a cobalt bit and stud remover. Tap them all first with a hammer to help break the corrosion bond before backing them out.
Finally happened......tick tick tick tick MDSuperDuty Modular V10 (6.8l) 5 11-15-2016 03:15 PM
Tips on removing Exhaust Manifold bolt?? jimkari Expedition & Navigator 11 02-06-2013 10:39 AM
broken exhaust manifold bolts custom cabby 1967 - 1972 F-100 & Larger F-Series Trucks 10 09-01-2010 02:18 PM
Exhaust Manifold -- Tube on Driver side? ebraunusa Expedition & Navigator 2 01-13-2010 11:18 PM
Another 460 exhaust manifold problem Ganggreen Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 12 08-05-2008 07:21 PM
Tags
1997, 390, 46, 97, bolt, bolts, broken, exhast, exhaust, expedition, f150, ford, liter, manifold, missing
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
