1994 F-150 accelerating problems - Ford Truck Enthusiasts Forums
Old 05-25-2011, 10:23 PM
chasegv chasegv is offline
chasegv is starting off with a positive reputation.
So today in michigan there was flash flood weather. on my way home i was driving through floods and it got high enough to reach my doors. i made it through the water just fine and i didnt even go fast through it cuz i didnt wanna mess up the truck. but a few take-offs after making it through the water, it began to accelerate really slowly and shift way too early. I didnt have much time to check it out yet. What could be wrong and do you think its engine problems or trans? now there is also a screeching problem under the hood and its more than just needing belt dressing...it seems like a rubbing more than anything. and twice i started the truck and it began to idle at 2 to 3 thousand rpms within a couple seconds, but went back to 900 to 1100 after i put it in drive. if anybody has a clue what happened it would be appreciated...thanks
Old 05-26-2011, 06:06 AM
TexasGuy001 TexasGuy001 is offline
TexasGuy001 has a very good reputation on FTE.TexasGuy001 has a very good reputation on FTE.TexasGuy001 has a very good reputation on FTE.TexasGuy001 has a very good reputation on FTE.
Welcome.
I bet the noise under the hood is a soaked pully and it may dry out.
The shifting could be from getting water in the transmission, just a guess here.
Don't ever use belt dressing.
Old 05-26-2011, 02:45 PM
not sure if thats it but who knows...i let it sit lastnight hoping any water would drain that is sitting but it still drove like crap today. what it seems like is if you were to be running out of gas and its on fumes, but it doesn't stall...i have a full tank too so im not sure if maybe my fuel pump is on its way out or something
Flooded Truck in Louisiana Renegade EX Excursion - King of SUVs 9 08-23-2016 09:21 PM
Hit around 2 feet of water at 60 mph lawdawg79 1999 - 2003 7.3L Power Stroke Diesel 16 12-29-2015 09:44 PM
86 E350 - 460 Carbed- Randomly backfiring and dying. areoseek 1968-2013 Full Size Vans 21 12-03-2015 01:21 PM
head gasket or cracked head on 1973 390 killertmac420 1973 - 1979 F-100 & Larger F-Series Trucks 10 09-07-2014 08:20 PM
Low alternator location and water - problem? troverman 2009 - 2014 F150 1 08-13-2014 04:23 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
