87 F350 Oil Pressure Sender location - Ford Truck Enthusiasts Forums
Old 05-25-2011, 10:05 PM
mcne2026 mcne2026 is offline
mcne2026 is starting off with a positive reputation.
I need to install a mechanical oil pressure guage to see if my oil pressure to low rpm's is as low as the stock guage says it is. I did a lot of searching and google, but can not find where the sending unit is. I have the big block, I think it is a 7.5l 460ci. Does that sound right?
Can someone point me to where it is, any special tool I will need and lastly, what it looks like. Never done anything like this before, but I am afraid to drive it all the way to town (50 miles through the Idaho mountains) with the low pressure reading on the stock guage.
Thanks all.
Old 05-25-2011, 10:45 PM
nebechanezer's Avatar
nebechanezer nebechanezer is offline
nebechanezer is starting off with a positive reputation.
On my '95 460, the oil pressure sending unit is on the top of the block, way in the back, behind the intake manifold.
Old 05-25-2011, 10:55 PM
Quote:
What does it look like and will I be able to reach it from the top? Should I remove the air filter housing to do it? Thanks for the help.
Old 05-26-2011, 05:47 AM
TexasGuy001 TexasGuy001 is offline
TexasGuy001 has a very good reputation on FTE.TexasGuy001 has a very good reputation on FTE.TexasGuy001 has a very good reputation on FTE.TexasGuy001 has a very good reputation on FTE.
I believe your truck already has a real oil pressure gauge. If it has the bigger sending unit on an extension then you have an actual gauge.
Idiot Light to Sweep Guage Conversion on a 64 F350 ihcc104 1961 - 1966 F-100 & Larger F-Series Trucks 35 02-27-2015 06:24 PM
Where is A/C high pressure port '06 F350? Ed Allen Cooling, Heating, Ventilation & A/C 2 07-30-2012 07:39 PM
low oil pressure steve mather 1987 - 1996 F150 & Larger F-Series Trucks 20 11-07-2009 07:44 AM
92 aerostar low oil pressure at idle... sachmo Aerostar 6 03-13-2004 12:41 AM
Location of oil pressure sending unit? Hank79 335 Series- 5.8/351M, 6.6/400, 351 Cleveland 6 12-27-2003 02:08 AM
Tags
1996, 2004, 460, 75, 75l, f350, ford, location, oil, pressure, presure, sender, sending, truck, unit
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
