Rough running engine at idle
What type of throttle position sensor is it- adjustable or non-adjusting? See this page for the difference- Ford Fuel Injection » Throttle Position Sensor (TPS)
If it's adjustable, you may have not installed it correctly. Even if it's non-adjustable, it could be installed wrong. You need to make sure there is spring tension on the sensor when installing.
I thought of that too, and I could swear there is a diagram somewhere that shows us how our plug wires are supposed to be routed to avoid cross fire but I couldn't find it.
Steve83 has some pics and info here: 1983 Ford Bronco Diagrams picture | SuperMotors.net for 5.0L plug wiring and firing order
JimiLL
15
12-09-2014 12:02 PM
JTD1972
11-19-2003 04:20 PM
wally2117
08-27-2002 10:20 PM
