04' Explorer front wheel bearing replacement - Ford Truck Enthusiasts Forums
Old 05-25-2011, 08:17 PM
Donny_D's Avatar
Donny_D Donny_D is offline
Donny_D is starting off with a positive reputation.
Hey guys im an older member i had a 99; F-350 and was from that forum. The wife and I picked up an explorer and the front wheel bearing is shot. Does anyone have a Chiltons break-down on how to replace the driver side front wheel bearing. Some more info on the car, its 04' ford explorer, with the 4.0. 4 w/d, not the sport track. Thanks in advance to anyone that can help.
Old 05-25-2011, 09:52 PM
steve(ill)'s Avatar
steve(ill) steve(ill) is offline
steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.
the 4 wheel drives have a hub / bearing unit that you replace. You do not change just teh bearing. Basically you jack up the tire, remove tire/ rim, remove the axle nut in the center lf the hub and push the alxe inward 1 inch. Remove brake caliper and disc. Reach around the backside of the hub unit and remove the 3 bolts holding the hub to the knuckle. Then pull the hub unit off... Works same as all front wheel drive cars and 4 x 4 newer trucks ( last 10 years or so). Bearings are permanent sealed, can not be greased.. I will post a youtube movie if i can find one... Bearing/ hub is about $200 at Auto Zone.. you can get one off e-bay for about $80. MOST are made in china these days.
Old 05-25-2011, 09:56 PM
steve(ill)'s Avatar
Old 05-26-2011, 11:56 AM
aquanaut20's Avatar
aquanaut20 aquanaut20 is offline
aquanaut20 is starting off with a positive reputation.
Good video, just like the one I repaired last month... Philip
Old 05-26-2011, 12:25 PM
dan8052's Avatar
dan8052 dan8052 is offline
dan8052 is starting off with a positive reputation.
One word of caution when replacing the hub/wheel bearings... you get what you pay for! I purchased 2 hubs from Advance Auto for my '96 Explorer and could tell the drivers side was bad before I made it past the neighbors driveway (50 ft.).
Old 05-26-2011, 07:13 PM
Donny_D's Avatar
thank you all for the posts i really appreciate the help.
Old 05-27-2011, 02:54 PM
1ATony's Avatar
1ATony 1ATony is offline
PREMIUM SPONSOR
1ATony is a splendid one to behold1ATony is a splendid one to behold1ATony is a splendid one to behold1ATony is a splendid one to behold1ATony is a splendid one to behold1ATony is a splendid one to behold1ATony is a splendid one to behold
We offer three different options on these.We carry generic, Motorcraft and also the Timkin bearings for this year Explorer.
Here's a link to them on the site.
2004 Explorer Bearing Hub Assembly
__________________
Like us on Facebook
SHOP HERE FOR AWESOME BRAKE PAD AND ROTOR KITS - FREE SHIPPING
04 explorer front axle nut size Jon Paulsen Explorer, Sport Trac, Mountaineer & Aviator 1 02-20-2016 08:23 PM
'96 Explorer Bad Wheel Bearings?... dan8052 Explorer, Sport Trac, Mountaineer & Aviator 4 03-16-2011 10:32 PM
Ranger/ Explorer D35 TTB questions... Pkupman82 Offroad & 4x4 4 01-30-2011 10:22 AM
1992 Explorer 4x4 Front wheel bearing torque ? zzrich Explorer, Sport Trac, Mountaineer & Aviator 2 04-11-2010 04:27 PM
Replacing Front Wheel Bearings GB04 Excursion - King of SUVs 7 09-09-2005 11:41 AM
Tags
04, 1994, 94, barring, bearing, bearings, explore, explorer, expoler, ford, front, mountaineer, replacement, sport, wheel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
