Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1987 - 1996 F150 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1987 - 1996 F150 & Larger F-Series Trucks 1987 - 1996 Ford F-150, F-250, F-350 and larger pickups - including the 1997 heavy-duty F250/F350+ trucksSPONSORED BY:
  #1 (permalink)
Old 05-25-2011, 02:12 PM
live24wheel live24wheel is offline
Garage is empty, add now
live24wheel is starting off with a positive reputation.
1997 F350 Intermediate Steering Shaft
Hello folks, I am new to this forum and looking for some advice on my F350 I recently purchased. It is a standard cab, 460, manual trans, 4x4. I have done a good amount on the interior to clean it up and make it a nice driver, such as rebuild the steering column, what a joy. I need to replace the intermediate steering shaft from the bottom of the column to the steering box. The bushing at the slip portion is completely gone. I was hoping to get a Borgeson replacement but upon further research, it doesn't appear they have one for my application. I contacted their tech department and they simply told me they don't have one for a 97. I also contacted the dealer and they told me they do have a replacement, at close to 200 bucks, they also told me the 97 intermediate shaft is a one and only for that body style. Can anyone shed any light on this? Are there any other options or manufacturer's I should look at?
I appreciate any advice on this.
Tom
  #2 (permalink)
Old 05-25-2011, 03:08 PM
Duct Tape Racing's Avatar
Duct Tape Racing Duct Tape Racing is offline
1988 Ford F-150
My Garage
Duct Tape Racing is gaining momentum as a positive member of FTE.
Welcome to the forums!
It might be a shot in the dark but there might be one sittin in a junk yard thats not too tore up, it doesnt hurt to look
__________________
Duct Tape Racing: 1994 F150 reg cab long bed 300/6.
Beauty: 1978 f250 ranger reg. cab long bed, dana 60/70 lockers f&r, 400m with mild build, 4 speed granny low, 4" lift on 35's
Current Project: 1972 f250 4x4 360v8 4 speed.
Daily Driver: 93 f250 4x4 5 speed 351W
  #3 (permalink)
Old 07-12-2011, 09:37 AM
hav24wheel's Avatar
hav24wheel hav24wheel is offline
1994 Ford F-150
hav24wheel is a splendid one to beholdhav24wheel is a splendid one to beholdhav24wheel is a splendid one to beholdhav24wheel is a splendid one to beholdhav24wheel is a splendid one to beholdhav24wheel is a splendid one to beholdhav24wheel is a splendid one to behold
Nice user name, looks familiar for some reason.lol
I've had good luck adapting junkyard shafts to my vehiclesnbefore. That's where I would start if I where you.
__________________
Dave
2003 Excursion Limited, V10, 3.73s, 285/75R16s
100% posting from iPhone
  #4 (permalink)
Old 07-12-2011, 01:20 PM
dclack's Avatar
dclack dclack is offline
1997 Ford F-250
dclack is starting off with a positive reputation.
Quote:
Originally Posted by live24wheel View Post
...they also told me the 97 intermediate shaft is a one and only for that body style...
I'm pretty sure that's a load of crap! I believe that all the steering components are the same from the column to the gearbox for all '92-'98 F150, F250, and F350's (I'm not 100% positive. Others on here will know for certain). If you want a new one, this shaft should work... Borgeson Steering Shaft. Like the others said, check the junk yard for a used one.
__________________
'97 F250, 7.3L PSD, ZF 5spd, CC, SB, 4" AFE intake, 3" dp, 4" straight pipe, 6" lift, 3.73 gears, D60 swap with ARB, 10.25ls rear, Glowshift Gauges and PHP tunes! Wish list: Rosewood stage 1s, Terminator T500 HPOP, IC
'73 Bronco, 302 HO, ZF 5spd, D20, D44 front, 9" rear, Detroits f&r.
  #5 (permalink)
Old 07-12-2011, 01:56 PM
Chaching Chaching is offline
Chaching is starting off with a positive reputation.
Hello folks, I am new to this forum and looking for some advice on my F350 I recently purchased. It is a standard cab, 460, manual trans, 4x4. I have done a good amount on the interior to clean it up and make it a nice driver Hid headlights , such as rebuild the steering column, what a joy. I need to replace the intermediate steering shaft from the bottom of the column to the steering box. The bushing at the slip portion is completely gone. I was hoping to get a Borgeson replacement but upon further research, it doesn't appear they have one for my application. I contacted their hid headlight Kits tech department and they simply told me they don't have one for a 97. I also contacted the dealer and they told me they do have a replacement, at close to 200 bucks, they also told me the 97 intermediate shaft is a one and only for that body style. Can anyone shed any light on this? Are there any other options or manufacturer's I should look at?
Tom
Yea your best bet would be to check your local junk yard for what you need.
  #6 (permalink)
Old 07-13-2011, 08:44 AM
jokerforever's Avatar
jokerforever jokerforever is offline
1997 Ford F-350
My Garage
jokerforever is gaining momentum as a positive member of FTE.jokerforever is gaining momentum as a positive member of FTE.
Quote:
Yeah, I used this one on my truck a few weeks ago. It works great but is a little tricky to get in. You may have to loosen the steering box.
Borgeson Universal 000981 - Borgeson Universal Steering Components - Overview - SummitRacing.com
Your truck is a lot like mine. You should check out what I'm doing.
http://www.ford-trucks.com/forums/99...350-build.html
__________________
  #7 (permalink)
Old 09-09-2011, 10:44 PM
Diesel_Dirk's Avatar
Diesel_Dirk Diesel_Dirk is offline
Diesel_Dirk is starting off with a positive reputation.
I am also in need of a new steering shaft and checked the Borgson site and was disappointed to see the listing stop at '96.
Is this verified that it fits a '97?
  #8 (permalink)
Old 09-09-2011, 11:22 PM
dclack's Avatar
1997 Ford F-250
Well I can't "guarentee" it will work because I haven't tried to use the Borgson. But remember that in '97 Ford started making a light duty F250 based off of the new F150 body. Therefore, a lot of companies just list parts for the '92-'96 not realizing that the '97 HD is the same truck. I just went down to the junk yard and grabbed a shaft (I doubt it was from a '97) and it fit right in my '97 F250. So yes, I'd put money on the fact that the Borgson will fit the '97 HD.
__________________
  #9 (permalink)
Old 09-10-2011, 08:22 AM
1997 Ford F-350
My Garage
Yes, it does fit. It's tight and you may have to loosen the steering box. I was swapping my box at the same time and had to wiggle it a little. But it does fit and fits great. Check my build thread^^
__________________
  #10 (permalink)
Old 09-10-2011, 04:37 PM
Thanks guys, I'll order one this week.
  #11 (permalink)
Old 10-12-2011, 12:57 PM
Borgson 000981 fits.
At the steering box:
Click the image to open in full size.
At the steering column:
Shaft is longer than stock though. Collapsed it is only about .5" shorter than the one shaft is extended.
I decided to shorten it by an inch to allow it to collapse a little more.
For comparison, old vs new:
I did notice that there is quite a bit of free play in the steering box input shaft.
New steering box is next I guess.
  #12 (permalink)
Old 06-10-2012, 08:53 PM
Donny Robinson Donny Robinson is offline
1997 Ford F-250
Donny Robinson is starting off with a positive reputation.
Smile I got a welder...
300 bucks for the new shaft? sounds like the SHAFT ...to me..I had this problem on a 78 bronco... just tacked it up.. now this problem on a 97 f 250..but I think I will try a u-bolt clamp first.....
  #13 (permalink)
Old 06-10-2012, 09:09 PM
Bigblue351's Avatar
Bigblue351 Bigblue351 is offline
1997 Ford F-250
Bigblue351 is starting off with a positive reputation.
just snagged a used shaft from a jy for 20 bucks. EASY to remove and bolt in. Alot better feel now.
I pulled out of a 94 f250 for my 97 f350. ( i think f250/f350 are the same) and noticed all the F150s looked different but wasnt really interested in looking.
Tags
1988, 1997, 450, 97, f250, f350, ford, intermedate, intermediate, lower, pic, shaft, slip, steering, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
