'05 F150 overdrive shifting problem - Page 2 - Ford Truck Enthusiasts Forums
Old 07-13-2012, 05:03 PM
johnjets johnjets is offline
johnjets is starting off with a positive reputation.
2005 f150
so did you go to ford or any one
Old 09-24-2012, 12:59 PM
jafeza jafeza is offline
jafeza is starting off with a positive reputation.
I have the same problem on my f150 2004. Do you now whats is the ploblem? this problem makes on tha 50-60 mph on the 4 shifth and when i put the buttom on of, the is les than the other
Old 09-24-2012, 04:13 PM
KC Excursion KC Excursion is offline
KC Excursion is starting off with a positive reputation.
Read the above posts and forum threads
Hey everyone,
There have been several excellent posts answering the question on this exact forum. I just went through this entire process myself, search my other posts for a detailed write up on transmission versus COPs. It starts with overdrive then progresses to drive....it feels like the car is being hit by something, let off the gas and the problem goes away.
I read every thread i could on this forum...by far the most common problem is:
1) COPs (Coil Over Packs) - mount directly to the spark plug
2) Spark Plug
Could it be the transmission or torque converter, yes, BUT until you do 1 and 2 above don't go there. A code will not always be thrown, it may turn on the engine light momentarily but self clear. I only registered a code once, all the other times were transient.
Old 09-25-2012, 08:33 PM
MtnMerk MtnMerk is offline
MtnMerk is starting off with a positive reputation.
06 Screw, RWD Automatic. Mine was doing exactly this. 120,000 miles, bought used with 78,000. Replaced plugs and all coils.No hesitation, no slack, just gets up and runs now. Broke 6 of the plugs replacing them. Local parts store has the tool to remove them as a loaner tool. Was much easier removing the broken plugs than I was led to believe. I got the plugs(Motorcraft), and all 8 coils(generic) off of the Auction site(ebay) for a total of $150. Stealer wanted $499 plus $50 per broken plug to do the work. and that didn't include the coils($79.95 ea). Now to figure out why I get the fuel odor when I first start it up. Going to pull number 8 plug, and check to see if it's seating properly, Did get a CEL indicating a miss there....wiggled the coil and connections a little, and the CEL went away. Which kind surprised me. Was figuring I'd need to clear it with a scan tool, or disconnect the battery, but neither was needed.
Old 05-05-2014, 04:47 PM
Mahansen81 Mahansen81 is offline
Mahansen81 is starting off with a positive reputation.
I have an 06' with about 160k and i'm getting the same symptoms according the maintenance records the plugs & coils were done around 130k. I'm not sure where to start as it doesn't seem like a coil should be bad already. any thoughts?
Old 05-05-2014, 05:34 PM
gijim2k1's Avatar
gijim2k1 gijim2k1 is offline
gijim2k1 is starting off with a positive reputation.
plugs or coils. plugs are cheaper so change those first. if that does not solve the problem try coils. Mine was solved with just plugs.
Old 05-06-2014, 03:05 PM
HazMatt6 HazMatt6 is offline
HazMatt6 is starting off with a positive reputation.
Quote:
Originally Posted by drew_goeke View Post
I recently had the transmission fluid in my 2005 F150 drained, flushed, and replaced by a local garage that has done great work in the past. Shortly after it was changed I noticed that between 45-55 mph if im cruising in overdrive (mostly in slow traffic) that the transmission will jerk the entire truck. If feels almost like I hit a pothole in the road.....but I know its the tranny jolting the entire truck. Furthermore, it only happens when overdrive is engadged and I press the gas just a little more, but not enough to make it down shift into 4th gear. I don't know if the tranny is trying to downshift and can't decided whether to or not, or if there is something internally wrong. Any information you can provide me with would be great.
At the moment this only happens when in overdrive. I fear that if I let this continue to happen I will lose OD completely or worse yet.....lose my entire transmission. What might this be due to?
Same thing here...took it to 3 shops including transmission shop and nobody can tell me whats wrong. The tranny place said it was not the transmission.
Old 05-06-2014, 03:51 PM
Ford'05HG's Avatar
Ford'05HG Ford'05HG is offline
Ford'05HG is gaining momentum as a positive member of FTE.Ford'05HG is gaining momentum as a positive member of FTE.
Coils. They're a pain in the anus. Not to work on, just living with. I just did 2 and I got at least another 1 or 2 to do. It makes the truck no fun when they break
Old 06-02-2014, 08:50 PM
Finke Finke is offline
Finke is starting off with a positive reputation.
Quote:
05 f150 with 240,000 miles. Same problem, took mine to a couple trusted mechanics. Change all of the coil packs. Why risk another failing soon after you change a coue bad ones. Pick them up after market on Amazon for $8 a pop. The front plugs are easy to do, the back ones need more time but you can knock out the front ones quickly & hit then back ones when you have more time. Or, take it in to have all of the plugs replaced & bring in the coils yourself & have them switch them at the same time. Any reasonable mechanic will do them for no charge, they have to pull them anyway.
The "low grade" misfire doesn't throw a code, but the computer picks up the misfire & is sending information for the tranny to shift & you feel the tranny shift hard.
I've had lots of other potential big issues solved through these forums. Tefinke@yahoo.com
E
Old 05-16-2016, 07:49 PM
Indianex82 Indianex82 is offline
Indianex82 is starting off with a positive reputation.
2007 f150 tranny shifting hard
my 2007 f150 shifts hard between 4th and OD. No CEL or codes. find it hard to believe it is a missfire. What should I check first before I start replaicing coilpacks?
Old 08-02-2016, 10:38 PM
Rickf15083's Avatar
Rickf15083 Rickf15083 is offline
Rickf15083 is starting off with a positive reputation.
Quote:
i had same problem and my misfire was caused by bad intake gasket.
i had coolant going on the piston.
replaced motor so its not the tranny even tho it feels like it
Old 11-20-2016, 12:16 PM
pebaugh pebaugh is offline
pebaugh is starting off with a positive reputation.
I had this problem on my 2005 F150 with the Triton engine. Being the senior engineer on advanced ignition systems in the late 70's and early 80's, at Chrysler, I pretty much knew what it was when the symptoms happened. I had bucking when in overdrive when going uphill or pulling a load. this bucking would stop when I downshifted and got out of overdrive. The problems is with this lower engine speed and load, the coil needs to put out a higher voltage to fire the coil (up to 30kv), The coil most likely has an internal crack in the epoxy in the coil which shorts out the secondary and causes a misfire resulting in the bucking.
Coil changed and issue solved. This most likley will occur again on the other coils over time.
Truck not going into overdrive hack 96' F150 lievense81 1987 - 1996 F150 & Larger F-Series Trucks 1 08-26-2015 07:38 PM
cost to rebuild aod fordboy97 1987 - 1996 F150 & Larger F-Series Trucks 10 03-05-2015 02:19 PM
aode transmission overdrive troubles 94GreenTruck 1987 - 1996 F150 & Larger F-Series Trucks 45 03-24-2014 11:26 AM
overdrive button not working [96 f150] jimbo beam 1987 - 1996 F150 & Larger F-Series Trucks 5 10-14-2006 10:09 AM
Lost overdrive on '02 F150 4.6L 4x4 EmmEff 1997 - 2003 F150 2 11-14-2005 08:12 PM
Tags
150, 1996, 2005, 2006, converter, f150, ford, forum, gear, jerking, nitrous, overdrive, problems, replacement, shifting, slipping
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
