1978 351W headers? - Ford Truck Enthusiasts Forums
1978 351W headers?
Old 05-24-2011, 10:59 PM
Weberman3 Weberman3 is offline
Weberman3 is starting off with a positive reputation.
1978 351W headers?
I've been looking and I can't find any headers at all for a 1978 F-150 351W.
Old 05-24-2011, 11:16 PM
HIO Silver's Avatar
HIO Silver HIO Silver is online now
HIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud of
You're not imagining things cuz the 351W wasn't offered in the Dentsides. Is your application 2WD or 4WD and manual or auto????
For long tubes, the closest you'll get is a 2WD with a 302. 302 shorties will work and I think it's hit and miss with 3/4 length headers (longer than shorties but not long-tubes).
Old 05-24-2011, 11:22 PM
It is a 2WD auto
Old 05-25-2011, 07:31 PM
V10man's Avatar
V10man V10man is offline
V10man is gaining momentum as a positive member of FTE.V10man is gaining momentum as a positive member of FTE.
I would be tempted to try a set for a 1980 truck.
Old 05-25-2011, 07:44 PM
That was my next question. Could I try and fit a different year or different model.
Old 05-25-2011, 10:01 PM
HIO Silver's Avatar
Quote:
Yeah. You could try 80-95 1/2 ton 2WD headers like Hedman Elites (Jeg's PN 500-89358).. there's no guarantee that they will fit though. They're 3/4 length according to the catalog's image.
The 351W has a one-inch taller deck height and is slightly wider than a 302. If you can fab, then order a set for a 302 for your year, extend the primaries, and maybe angle them to compensate for the increase in width. Your auto trans makes things a bit easier since there are no linkages to deal with.
I did a search in the 73-79 forum for "351 headers" and came up with 17 pages of hits. A quick scan of the results indicated some fellow FTE'ers went with shorties.
Old 05-26-2011, 12:01 PM
Wouldn't really want to go to shorties but if I have to I guess I will.
Old 06-09-2011, 11:18 AM
daveengelson daveengelson is offline
daveengelson has a good reputation on FTE.daveengelson has a good reputation on FTE.daveengelson has a good reputation on FTE.
Same issue w/ 65 did not come with a 302; understand chassis same/simular 65-78, found Hooker longtube worked. Had to lift passenger side slightly to get the header around the starter. In addition, used 4 1/2" grinder to remove small amount of metal on passenger side engine crossmember I wanted additional clearance for header flange. Seem to recall thread on simular topic, believe member mentioning the 351w will set slightly higher than the 302. Not sure about shorties. Just had exhaust system installed found experienced shop can install for just about any application. Anyhow, food for thought.
351m/400 headers on 460? BigCountry1978 1973 - 1979 F-100 & Larger F-Series Trucks 1 07-16-2016 02:05 AM
flowtech headers vs starter yak 1973 - 1979 F-100 & Larger F-Series Trucks 1 03-28-2015 11:30 AM
Will 80's f150 headers fit my 78 f100 w/351w? cjben Exhaust Systems 2 01-26-2004 06:55 PM
351w and 302 interchangable headers? for conversion jimbo81587 Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 1 01-22-2003 11:06 PM
I need headers for 351M in 1978 T-Bird!!! Kenny Exhaust Systems 2 11-18-2000 06:36 PM
Tags
1977, 1978, 1980, 351w, 450, 97, f100, f150, f250, fit, ford, headers, manual, trans, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
