PMC update and Smoke - Ford Truck Enthusiasts Forums
6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Old 05-24-2011, 08:02 PM
Bruce P Bruce P is offline
Bruce P is starting off with a positive reputation.
I got my requested for the PMC update to my 2008 F250 job 1 SD last week and been waiting as I have noticed a few problems with others who had the update. I also heard there was a new PMC program coming from Ford mid May 2011 so I will wait and see.
Also, fairly new to the Ford diesel scene and I had my first white/blue smoke shutter twice last week but it was in the rain. Very wet and after reading all the comments about the CAC update I assume I had water in the intake??How would I know wheather the truck had a CAC update from Ford. Any tell tail signs or do I need to check with the dealer using the VIN.
Also have the engine making a bit of oil after 6000K and now due for an oil change but does not seem too bad- Should I be concerned and have a oil analysis?
PS: Great site & group, I have been on here a few yrs with updates to my 1986 F150 4x4
Bruce P
Old 05-24-2011, 10:07 PM
senix's Avatar
senix senix is offline
senix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputation
Yes there is an update to the update. Best to wait a bit longer as most dealers are unaware of it at this point.
As far as you smoke and shutter...or studder some call it. That does sound like the cac with water in it issue. Taking the lower boot off the cac and letting it drain may help..or better yet some WOT (wide open throttle) events will help to keep it cleaned out as well.
Getting the dealer to run your vin..an oasis report is the only way to see if the cac was ever replaced.
Old 05-24-2011, 11:01 PM
caprang's Avatar
caprang caprang is offline
caprang is gaining momentum as a positive member of FTE.
If you are at 6000 miles on your oil CHANGE IT ASAP. These engines live and die by extreme maintenance schedules. If its a used truck I would change the fuel filters to be safe too.
I had the CAC replaced and it didnt help. Some report an improvement, others dont notice any difference.
Old 05-25-2011, 08:59 PM
PMC Update & smoke
Thank guys for the input- I will wait on the PMC update. See what turns out on this site as Ford gets up to speed on this update.
My oil only has 4000 KM on it our about 2500 miles and it is up over the full line slightly but I think I will do the oil and all filters as you suggest-ASAP
CAC update I've heard varying results on th Ford upgrade (Just on this site)- but if it is a free install a slight upgrade is better then none.
Seems the DFP delete is the way to go (after warranty) and I will wait until the warranty is expired and then think about this upgrade.
Bruce P
ford WONT cover updates to TCM/PMC WARRENTY Refrigeration Tech 1999 to 2016 Super Duty 4 10-24-2014 05:37 PM
TPS problem aa767man Expedition & Navigator 3 04-14-2012 10:42 PM
recon engine 4.2 pmc 3.8 & 4.2L V6 1 06-13-2007 09:23 PM
DP Tunner install ? luvemhot 1999 - 2003 7.3L Power Stroke Diesel 4 06-02-2007 12:30 PM
installing external transmission filter aurgathor Clutch, Transmission, Differential, Axle & Transfer Case 4 03-27-2005 02:52 PM
Tags
150, 1997, 1999, 73l, 97, f250, f350, ford, pmc, reprogram, slipping, swap, transmission, truck, updates
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
