How To: Power Steering Pump Replacement - Page 2 - Ford Truck Enthusiasts Forums
Old 11-24-2014, 05:46 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Steering and Suspension Guides
Print Wikipost
Old 05-31-2011, 09:06 PM
thrillbillydlux thrillbillydlux is offline
thrillbillydlux is starting off with a positive reputation.
could the fact that ford uses ATF instead of PSF be why when i turn i sometimes feel like there is a loss of steering momentarily and occasionally while driving straight? by the way thanks for the post, will be useful if i do end up having to replace/flush my PSP.
Old 05-31-2011, 09:12 PM
ArdWrknTrk ArdWrknTrk is offline
pedant
ArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputation
Could be a slipping belt or pump cavitation.
The recommended ATF is the correct viscosity and works with the seals in the system.
Old 05-31-2011, 09:15 PM
wildbill70cuda wildbill70cuda is offline
wildbill70cuda is starting off with a positive reputation.
2000 Ford Excursion, changed power steering box but still have no power steering unless raving the truck up. Any suggestions. The fluid is filled. I checked the system for flow and that's fine. No restrictions, no clasped hoses. That's where I'm at. What should I try next?
Old 06-01-2011, 02:25 AM
xxshine xxshine is offline
xxshine is starting off with a positive reputation.
I did away with the power steering on my 89 F-150 6 Cyl. Put a manual steering gear box in the place of. Hydraulic power steering is a thing of the past. It was old when it was new, cause of all the problems that went with hydraulic, and the weight too. Now there's electronic power steering.
Old 06-02-2011, 07:42 AM
nstueve's Avatar
nstueve nstueve is offline
nstueve has a great reputation on FTE.nstueve has a great reputation on FTE.nstueve has a great reputation on FTE.nstueve has a great reputation on FTE.
Quote:
You changed the steering box or the pump?
PS: you might try the Ford Excursion forum. The users there would have better ideas for you... My knowledge of Ford Trucks is stuck back in 1991 and earlier.
http://www.ford-trucks.com/forums/forum29/
Quote:
Not a bad idea if you want to spend $300+... From what I've read you can delete the PSP but you have to replace it with a electric motor to drive the new EPS. On old trucks like ours your going to need a 95-130amp alternator upgrade to drive it and recharge the battery after the extra drain. (newbies: A common 2G-to-3G swap with a Ford Taurus alternator is the prevalant option for upgrading alternators) Plus on the newer cars with EPS, the electric motor is mounted on the steering column itself...
Is there a bolt on option for our trucks? what is the amp draw from the electric motor? IF you have on your truck LET'S SEE PICS!
I'm all up for give FTE users/readers all the options!
Electric Power Steering
Old 06-04-2011, 01:31 AM
Don't have electronic power steering. Was just saying that hydraulic power steering was old when it was new. I put a manual steering gear box on. The motor just turns a Taurus alternator and water pump ( minus the clutch fan ). Electric fan replaces that ancient clutch fan.
Old 06-04-2011, 03:31 AM
pedant
Ahhhh, Now I see.
(from the Wiki)
"An engine or motor is a machine designed to convert energy into useful mechanical motion.
Devices converting heat energy into motion are referred to as engines, which come in many types. A common type is a heat engine such as an internal combustion engine which typically burns a fuel with air and uses the hot gases for generating power.
Another common type of motor is the electric motor. This takes electrical energy and generates mechanical motion via varying electromagnetic fields."
Old 06-07-2011, 09:07 AM
nstueve's Avatar
Quote:
Originally Posted by ArdWrknTrk View Post
Ahhhh, Now I see.
(from the Wiki)
Do I detect a hint of sarcasm about the links I used??? I was just trying to post a few links that would help newbies see the difference. I'll admit, I didn't read the Elect Power Steering link... I was just using it for a visual.
Doesn't a manual steering box make steering the vehicle harder? My mom used to have a Pontiac Fiero that had a manual steering box and that thing was kind of a b**ch to turn...
PS: you could technically get rid of everything except the alternator... If you really wanted to see how much drag the accessories put on the motor you could get a elec fan, elec PSP, elec water pump, and elect AC compressor/motor.
Old 06-07-2011, 11:27 AM
pedant
No sarcasm.
When I think of a "motor" I think electric, or something else where power is directly applied to it.
I refer to an (internal combustion) "engine" when speaking of what provides motive force to our trucks.
Fuel is consumed to create heat that provides the mechanical motion.
xxshine stated his "motor" only turns the alternator and water pump.
I can see how that could be misconstrued.
Old 06-07-2011, 01:07 PM
nstueve's Avatar
10-4.......
Old 11-14-2012, 10:51 AM
WCluck WCluck is offline
WCluck is starting off with a positive reputation.
thanks
thank you from a new ford owner, just bought a 93 xl 150 2 weeks ago, and had a bad whine start saturday. already replaced the pump thanks to this info.
Old 03-15-2013, 02:58 PM
bbqllejo bbqllejo is offline
bbqllejo is starting off with a positive reputation.
Very good write up thanks now i can start my project up this weekend and hopefully finish it sunday
  #28
Old 12-17-2013, 07:17 PM
66F250CS's Avatar
66F250CS 66F250CS is offline
66F250CS is starting off with a positive reputation.
OK - so I have a 1966 F-250 in which the PO installed a nice 1988 block 460. We have the same PS pump and bracket. We need to get the PS pump off the bracket. We now see how to do that - THANKS! So now, how do you get the pulley back on? Somehow reverse the puller? Maybe this is a completely stupid question, but humor me
  #29
Old 12-17-2013, 07:31 PM
pedant
The end of the shaft should be threaded.
You can pull it on with a long bolt, using a nut and washer.
  #30
Old 12-17-2013, 08:38 PM
66F250CS's Avatar
OK, that was a stupid question! Thanks
1975 F250 Crew Cab CCSB Daily Driver Build phlegm 1973 - 1979 F-100 & Larger F-Series Trucks 26 03-24-2016 03:13 PM
Manual Injector Cleaning - The How To Thread nstueve 1987 - 1996 F150 & Larger F-Series Trucks 56 08-26-2015 03:06 PM
HOLY SCORE, BATMAN!! vntgtrk 1957 - 1960 F100 & Larger F-Series Trucks 49 03-16-2014 05:42 PM
75 f250 supercab 12v cummins finally outta the garage pruitt 1973 - 1979 F-100 & Larger F-Series Trucks 34 04-26-2013 07:08 PM
Weekend suspension work (WITH PICS) nstueve 1987 - 1996 F150 & Larger F-Series Trucks 58 03-31-2012 11:42 PM
Tags
46, 97, catching, explorer, f250, ford, forum, high, hose, power, pressure, pump, ranger, replacement, steering, stering
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
