how do you id a flathead ? - Ford Truck Enthusiasts Forums
Old 05-23-2011, 10:02 PM
arrowheadfred's Avatar
arrowheadfred arrowheadfred is offline
arrowheadfred has a good reputation on FTE.arrowheadfred has a good reputation on FTE.
I never even made it home with it but would like to know what these number mean. Head had EAB on them/intake had 8BA-8RT 8520 /Back of the block had 31841.4 [i think] / water pump had 8RT-8503-B Will any of these numbers tell you what year it is ??????
Old 05-23-2011, 10:11 PM
fifty-two_f1's Avatar
fifty-two_f1 fifty-two_f1 is offline
fifty-two_f1 is starting off with a positive reputation.
EAB were 53 engines that had the 110 horse cam. 8BA was a typical 49-52 car engines a lot of them made their way into the trucks. 8RT was a truck engine. 52-53. I am not sure if they were put into the 48-50s.
Old 05-23-2011, 11:50 PM
ALBUQ F-1's Avatar
ALBUQ F-1 ALBUQ F-1 is offline
postin' fool
ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.
Old 05-23-2011, 11:59 PM
thanks ROSS i bookmarked it so i will always have it.
Old 05-24-2011, 12:21 AM
52 Merc's Avatar
52 Merc 52 Merc is offline
52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of
I have a theory, based solely on the fact that I own one and have seen a few others the same way, and sounds logical inside my peabrain, that when 8BA's were sent off for remanufacturing as core engines when replaced, the heads were replaced as a matter of course with the current production pieces, which after 1953 would have been the EAB part. My 1951 date coded engine removed from some kind of larger truck came to me with EAB heads on it. Feel free to debunk or agree at will. ;-)
Dale, for finding your engine's birthday, check out this link. The casting numbers you found won't do that.
birthday
Old 05-24-2011, 01:13 AM
THANKS WAYNE Thats simple as it gets
Old 05-24-2011, 07:36 AM
4tl8ford's Avatar
4tl8ford 4tl8ford is offline
4tl8ford is a splendid one to behold4tl8ford is a splendid one to behold4tl8ford is a splendid one to behold4tl8ford is a splendid one to behold4tl8ford is a splendid one to behold4tl8ford is a splendid one to behold4tl8ford is a splendid one to behold
In the 63 years since the "Modern" Flatmotor appeared they have become to resemble McDonald's Chicken Nuggets - They have been taken apart scrambled around and squeezed back together as a working Flathead
I'm not sure that if I found a pristine zero mile V8 Ford from that era that I would completely believe it was "Original"
Old 05-24-2011, 08:46 AM
55 f350's Avatar
55 f350 55 f350 is offline
55 f350 is a splendid one to behold55 f350 is a splendid one to behold55 f350 is a splendid one to behold55 f350 is a splendid one to behold55 f350 is a splendid one to behold55 f350 is a splendid one to behold
mine is a 52 block .... i.e. a factory rebuild as all casting numbers other than strange symbols , exist , and when it goes back together it will be a hodge podge of the best oe parts and a couple of gm pieces , that i can find . in other words like dick said ain't no such thing as an all oe flatty ................................ ( untouched but cleaned up short block , .010 milled eab heads for more compression , merc intake , rochester 2 jet , gm points dizzy converted too electronic , 8cm merc cam , blah , blah , blah ... and it's all " stock " )
Old 05-24-2011, 08:48 AM
ALBUQ F-1's Avatar
postin' fool
Wayne, I don't think they replaced a lot of stuff with new, I think the shops had pallets of cleaned/machined heads and just slapped a set of matching heads on when an engine came in for reman. The differences between 8BA 8RT and EAB heads aren't really noticeable on the street IMO, the differences in the blocks are truly minor. I've heard many stories about taking a well-used but running engine out of the family car to keep a truck on the road.
The engine in my truck as it came to me is a ('51) 1BA block, with EAB crank and heads, Merc oil pan, 8RT intake, and twin narrow belts (car setup). Scrambled up as Dick says. There's no real reason to get wound up on what exact year or model a flatty is, if it runs just enjoy it!
Old 05-24-2011, 09:02 AM
jmadsen's Avatar
jmadsen jmadsen is online now
jmadsen is a name known to alljmadsen is a name known to alljmadsen is a name known to alljmadsen is a name known to alljmadsen is a name known to alljmadsen is a name known to all
Speaking of rebuilt flatheads, I have had and seen a few "rebuilt" flatheads that have had the 8BA, EAB, or 8RT etc ground off of the heads.
The first one I saw like this had one head with smooth casting and the other with a smoother casting. makes me wonder if they were different heads altogether?? the rebuilt engine in the 53 C600 has the numbers/letters ground off as well.
Old 05-24-2011, 11:04 AM
mtflat mtflat is offline
mtflat has a good reputation on FTE.mtflat has a good reputation on FTE.mtflat has a good reputation on FTE.
My "EAB" heads had the casting #'s ground off. I only know that's what they were because I took time to cc them. Plus the rebuilt engine they came from had an EAB crank.
Has anyone ever seen an intake that was marked anything BUT 8BA/8RT 6520? From what I've seen that casting number was used from 48 thru 53 on Ford cars and trucks.
The only variation Ford used was the merc intake for the teapot carb with 4 bolts.
Old 05-24-2011, 02:48 PM
ALBUQ F-1's Avatar
postin' fool
For US Ford intakes, yes, that's what mine says too. The only other kind I've seen is Canadian aluminum Ford manifolds, which are C8BA (I've only seen one so I can't say if there are other Canadian designations)
Old 10-26-2015, 08:05 PM
desertob12484 desertob12484 is offline
desertob12484 is starting off with a positive reputation.
id my ford flathead V8
I have a Flatty and it has a casting number of G1724 on the back of the motor. trying to figure out what this motor is. can anyone help?
Old 10-26-2015, 08:41 PM
ALBUQ F-1's Avatar
postin' fool
The casting numbers don't tell you much. Visually we can ID it from a picture, if you can post some here. Are the water outlets at the front of the heads?
Old 10-26-2015, 08:45 PM
Quote:
Which Thermostat Part number is right for my truck? ag-ford-4x4 1997 - 2003 F150 5 11-13-2016 09:23 PM
8RT / 8BA heads Ian-1949/F47-1949 Flathead V8 & Flathead 6 5 07-10-2016 07:55 PM
Holley 94's: So many models, which is proper for me??? mercury_kid 1948 - 1956 F1, F100 & Larger F-Series Trucks 4 03-28-2009 10:52 PM
8CM vs. 8RT vs. 8BA heads - differences? Narwhal Flathead V8 & Flathead 6 3 01-04-2006 12:19 AM
Difference between 8RT & 8BA heads loudfords Flathead V8 & Flathead 6 1 08-23-2004 03:32 PM
Tags
6520, 8ba, 8rt, casting, codes, engine, flat, flathead, ford, head, identify, numbers, pump, raptor, v8, water
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
