Code P1131 - Ford Truck Enthusiasts Forums
Code P1131
Old 05-23-2011, 06:29 PM
ljemmer465 ljemmer465 is offline
ljemmer465 is starting off with a positive reputation.
Code P1131
I have a 2001 Exrursion 5.4L V8. The code P1131 comes up and it says "Lack of upstream heated oxygen sensor switch - secsor indicates lean - bank #1". I hear it could be the sensor that is bad or there is a vacume leak. It runs like a champ, no spitting, no sputtering, no missing, no ruff iddle. What do I need to do to fix it or where do i need to start looking? Thanks.
Old 05-23-2011, 08:44 PM
Thor80 Thor80 is offline
Thor80 is starting off with a positive reputation.
Copied from another ford Forum. Kudos to Phantom_Smack from fordforums.
P1130 - Lack of HO2S-11 Switch, Fuel Trim at Limit The HEGO Sensor is monitored for switching. The test fails when the HO2S fails to switch due to circuit or fuel at or exceeding a calibrated limit. Electrical:
Short to VPWR in harness or HO2S
Water in harness connector
Open/Shorted HO2S circuit
Corrosion or poor mating terminals and wiring
Damaged HO2S
Damaged PCM
Fuel System:
Excessive fuel pressure
Leaking/contaminated fuel injectors
Leaking fuel pressure regulator
Low fuel pressure or running out of fuel
Vapor recovery system
Induction System:
Air leaks after the MAF
Vacuum Leaks
PCV system
Improperly seated engine oil dipstick
EGR System:
Leaking gasket
Stuck EGR valve
Leaking diaphragm or EVR
Base Engine:
Oil overfill
Cam timing
Cylinder compression
Exhaust leaks before or near the HO2S(s)
A fuel control HO2S PID switching across 0.45 volt from 0.2 to 0.9 volt indicates a normal switching HO2S.
P1131 - Lack of HO2S-11 Switch, Sensor Indicates Lean A HEGO sensor indicating lean at the end of a test is trying to correct for an over-rich condition. The test fails when the fuel control system no longer detects switching for a calibrated amount of time. See Possible Causes for DTC P1130
Old 04-02-2013, 07:50 PM
Buck268's Avatar
Buck268 Buck268 is offline
Buck268 is starting off with a positive reputation.
Thats quite a list of causes. Obviously the leaky manifolds are a common issue with these trucks, what would a few other top suspects be?
If you haven't guessed, my '99 recently popped the P1131 code, although it only happens occasionally (doesn't come back right away if I clear the codes with a scanner).
Old 04-02-2013, 10:43 PM
bigwhitetruck01's Avatar
bigwhitetruck01 bigwhitetruck01 is offline
bigwhitetruck01 is gaining momentum as a positive member of FTE.bigwhitetruck01 is gaining momentum as a positive member of FTE.
I got that code twice so far. Reset the pcm and it went away. I'm still considering replacing both O2 sensors but i'll likely wait to see if this thread takes off and can provide me with a bit more insight. The.last thing I wanna do is just start throwing parts (and $$) at the truck.
codes po308, p1131 ,p1151 casanova76 1997 - 2003 F150 1 03-14-2015 06:22 PM
Plz need help with a 4.6 Bartramk Modular V8 (4.6L, 5.4L) 2 08-12-2014 02:18 PM
Aerostar P1131 P0133 codes help Brandon50394 Aerostar 7 09-18-2012 02:43 PM
error code p1131 96 ranger tonyc79 Ranger & B-Series 3 09-11-2009 08:37 AM
New Member: P1131 code on '96 4cyl jkward Ranger & B-Series 4 09-25-2004 12:45 PM
Tags
01, 03, 46, 54, 54l, code, excursion, f150, f350, ford, headswap, p01131, p1131, truck, van
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
