Limited SLip question...
05-23-2011, 05:25 PM
I know that a Limited slip from a 10.5 superduty rearend will fit a 10.25 rear, my question is does it have to be from the same gear ratio?
Could I use a LS from a 10.25 rear with 4.10's in a 10.25 rear with 3.55's?
Or could I use one from a 10.5 rear with 3.73's in a 10.25 rear with 3.55's?
05-23-2011, 05:35 PM
Yes. You will need to change the pinion bearing and seal in order to use the 10.5 gears in the 10.25 rear end though.
05-23-2011, 06:43 PM
Ok, but a LS from a 10.25 rear with 4.10's would fit a 10.25 rear with 3.55's?
05-23-2011, 06:53 PM
As far as I know yes... but ask someone who's got more knowledge than me. Tjbeggs where are ya?
05-23-2011, 08:05 PM
Yes, you can use the limited slip with all gear ratios.
05-23-2011, 08:18 PM
the 10.5 and 10.25 carriers are interchangeable without issue. Chase is correct about the ring and pinion
05-23-2011, 09:05 PM
05-23-2011, 10:54 PM
on
thats what i went threw, got myself into a whole mess thinkig i can set my own backlash, its expensive ill tell ya that. not too many shops..actually 99& of shops dont do them because you need a few specialty tools. its not that bad once you figure it out.
05-24-2011, 10:46 AM
Quote:
Originally Posted by
rideracelivemx7
I was quoted $650 plus parts to install 3.73 gears in my truck... I think I'll live with crappy fuel mileage!
05-24-2011, 10:58 AM
superduty4x4
Maybe the crappy fuel mileage is for the rims, bug deflector and sunvisor. IDK.
05-24-2011, 11:21 AM
RÖENTGEEP
Quit picking on my underpowered, fuel wasting ugly truck
05-24-2011, 01:27 PM
I'm happy with my 3.55 gears, just want both back tires spinning...
05-24-2011, 01:49 PM
on
so are the 3.55 gears or the 4.10's better for towing? I am sure I read this on another post somewhere but can't remember where...
Thanks
05-24-2011, 02:00 PM
4.10's are better. More rpms from the lower gear. Better take off power as the rpms come up quicker.
05-24-2011, 02:06 PM
on
sorry for the
Evan... How can you tell what Gear ratio you have?
