302 distributor install - Ford Truck Enthusiasts Forums
Old 05-23-2011, 12:42 PM
desertrat55 desertrat55 is offline
desertrat55 is starting off with a positive reputation.
I have a 1973 bronco 302 with stroker kit. just installed a new Edelbrock Air Gap intake and Edelbrock 600 cfm carb. Changed out from a 600 Holley. Problem is the distributor re install. Prior to removal I marked the cap and body at the number 1 wire and also marked the distrib shaft to the block for refereence on re install. Only error I made was not pulling the cap to reference the rotor alignment. I believe it may be 180 degrees off because it will not fire and backfires out the carb. Also, looking at a variety of on line diagrams, most indicate that the number one position on the cap is at 1 o'clock. Mine is at 5 o'clock but correct based on the position of the hold down clamps. If I am out of time by 180 degrees, can I remove the distrib. and still bump the motor, using a remote starter to bring it into alignment without any issues.
Any input would be appricated.
Old 05-23-2011, 06:04 PM
gfw1985's Avatar
gfw1985 gfw1985 is offline
Cranky Old Guy
gfw1985 is a name known to allgfw1985 is a name known to allgfw1985 is a name known to allgfw1985 is a name known to allgfw1985 is a name known to allgfw1985 is a name known to all
I have never seen a cap you could put on with the #1 marking on cap at five o-clock. Five 0-clock should be close to where the vacuum canister is pointing. The number really means nothing, just a ref. Best thing to do is bring #1 to TDC on compression stroke and reinstall distributor so rotor is pointing to #1 plug wire, then follow your timing order counterclockwise around the cap with the plug wires. Orientate the vacuum can where you have room to move it without hitting anything.
Old 05-23-2011, 06:19 PM
Correct, the vac port is at roughly 5 o'clock and my cap marking for number one spark wire, prior to pulling the distrib out, is one terminal "clockwise", of vac port. Then going counter clockwise through the sequence 1-5-4-2-6-3-7-8. So I guess it really does not matter how I put the cap back on and in what position as long as the rotor is pointing to the #1 terminal.
Old 05-24-2011, 09:27 PM
Boba Fett's Avatar
Boba Fett Boba Fett is offline
Boba Fett is starting off with a positive reputation.
Do you have a simple compression gauge? Try to track one down.... I would remove all the plugs. Install the compression gauge on the #1 plug hole..... and use the big 2' ratchet on the balancer bolt and spin the engine around until you see the timing marks lining up with the pointer and the compression gauge showing compression....
If you dont have the gauge you can have a friend use a finger in the plug hole to feel for compression....the set the timing about 10 before TDC and drop in the distributor pointing at the #1 lug...then the engine should fire over no problem.
Old 01-07-2012, 10:26 PM
benshere benshere is offline
benshere is starting off with a positive reputation.
installing dizzy
You can do all sorts of things to make sure that the #1 piston is actually up on the compression stroke and not 180 deg out. It can be pointing to # 1 on the intake stroke and would not fire or would backfire.
There numerous ways to verify that it is on the compression stroke, finger over plug hole etc. which are all good ways to check.
I have done so many dist pulls on fords (will pull the dizzy to replace/adjust springs and weights etc.) that I have found a simpler way--for me anyway!
When you put in the dizzy at first, with the pointer on the TDC--or slightly advanced, and the rotor on #1, dont worry about which stroke its on. If it is getting fuel and spark, then it should fire up and run. If it dosnt and sounds funny, you know you are 180 deg out. Dont worry about trying to get back to the TDC. Pull the cap and which ever cylinder the rotor is pointing to, pick the one directly across the cap from it and mark something on the manifold or close to orient the dizzy then turn the rotor and shaft until it lines up with the opposite wire and set the dizzy back down. You will have to learn where to start because of the gear bevels on the dist gear to make it wind up correct when seated. It will not just drop straight down and in. It will,more than likely, not line up with the oil pump shaft, but just tap the starter lightly until it drops all the way down.
If it dosnt start there either, you have some other problem. After it starts, you can do the timing thing. It is much easier for me than trying to pull plugs or valve covers. Remember you have a 50/50 chance of getting it right on the first try. If not right, its not nearly as much trouble! Sorry if this is long-winded
Old 01-09-2012, 09:29 PM
Boba Fett's Avatar
That is an awesome trick.... I know a lot.... But never would have figured that out on my own.... Thanks
Old 03-09-2012, 01:27 AM
texasft texasft is offline
texasft is starting off with a positive reputation.
So... after u have found TDC and pointer is facing #1 cylinder (on compression stroke) and distributor is fully seated, u can put cap on and it doesnt matter where the plug wire goes on cap, as long as it goes to #1 cylinder? I found TDC, put cap on, turned engine over until I got oil pressure, and now I dont know where the #1 plug wire goes on the cap. Can someone help please?
Old 03-17-2012, 04:11 PM
Nevermind👌
Old 03-18-2012, 08:28 PM
chrlsful's Avatar
chrlsful chrlsful is online now
chrlsful has a good reputation on FTE.chrlsful has a good reputation on FTE.chrlsful has a good reputation on FTE.
Nevermind��
bronco success?
Old 03-20-2012, 08:05 PM
Yes, purring like a lion until I get the mufflers put on👍👍
Old 03-20-2012, 09:53 PM
chrlsful's Avatar
excellent! any pic?
Old 08-08-2014, 02:09 PM
Allan Hauge Sr. Allan Hauge Sr. is offline
Allan Hauge Sr. is starting off with a positive reputation.
I am re installing a distributor in my 302 and I can not get the half inch to seat what is it?
Old 08-08-2014, 04:50 PM
Tedster9's Avatar
Tedster9 Tedster9 is offline
Tedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputation
Try turning the crank over by hand just a bit, maybe an eighth or quarter turn
Sent from my iPhone using IB AutoGroup
Old 08-09-2014, 07:23 AM
gfw1985's Avatar
Cranky Old Guy
Quote:
Oil pump shaft not seated in distributor shaft. Don't try forcing it, or you will be back here with other issues. Look down opening with distributor out and you will see the hex shaped shaft. Centering shaft in hole with a dab of vasoline to hold it in place helps..
How to Save Installing 18 of 24 Followers on a Timing Job. macubus 2004 - 2008 F150 5 02-05-2017 03:08 PM
CDR-factory hole or rust-through? VT tree grower 1987 - 1996 F150 & Larger F-Series Trucks 8 01-03-2017 10:58 AM
Ford 302 Timing Gear Alignment bsraborn 1973 - 1979 F-100 & Larger F-Series Trucks 6 09-05-2016 08:36 PM
92 f 250 5.8l timing issue Rigby New Member Introductions 4 07-07-2015 01:41 PM
NEW Edelbrock Performer RPM and NEW distributor jaydgraff FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 16 04-30-2013 10:08 PM
Tags
180, 302, bad, clutch, degrees, distributor, fire, ford, install, installation, installed, installing, orientation, pic, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
