4x4 issue!
Old 05-23-2011, 01:18 AM
a ayala's Avatar
a ayala
a ayala is offline
4x4 issue!
its a 1991 ford f250 4x4, and i noticed that when i put it in 4x4 it didnt feel like 4x4 so, i jacked up the rear end, locked the hubs and tryed 4hi and 4lo, all that happins is the front diff spins and the tires wont! whats my problem?
Old 05-23-2011, 03:14 AM
zxwut?'s Avatar
zxwut?
zxwut? is offline
Open up your hubs.
Old 05-23-2011, 08:53 AM
nstueve's Avatar
nstueve
nstueve is offline
If you are saying that in 4hi and 4low the transfer case does spin the shaft going to the front diff... and the front diff doesn't spin the wheels then you have 1 of 2 problems...
Bad hubs or problem in your front diff...
Like zxwut said... open up your front hubs for inspection.
Old 05-23-2011, 08:54 AM
CWPottenger's Avatar
CWPottenger
CWPottenger is offline
Sounds like bad hub locks
Old 05-23-2011, 11:20 AM
cj06's Avatar
cj06
cj06 is offline
double check that your hubs are actually in the locked position , all it takes is for one to be unlocked and it wont work ! i have done that myself on more than one occasion !
Old 05-23-2011, 11:55 PM
a ayala's Avatar
a ayala
a ayala is offline
the hubs are bolth locked in and it still dosent work !!
Old 05-24-2011, 02:43 AM
zxwut?'s Avatar
zxwut?
zxwut? is offline
Open up your hubs.
Old 05-24-2011, 07:40 AM
nstueve's Avatar
nstueve
nstueve is offline
Originally Posted by zxwut?
Open up your hubs.
x2...........
Old 05-24-2011, 10:28 AM
dclack's Avatar
dclack
dclack is offline
Lift the front and spin each tire back and forth with the hubs locked and see if the axle spins with it. This will tell you which hub is bad.
joeskeeter
1999 to 2016 Super Duty
02-21-2008 10:23 AM
navyflyinggreg
04-24-2007 02:04 PM
nobull4x4
01-23-2005 03:55 PM
4x4x4x4
09-30-2002 03:55 PM
stoab
09-10-2002 01:13 AM
Quick Reply: 4x4 issue!
