70's 351 Serial #? - Ford Truck Enthusiasts Forums
70's 351 Serial #?
Old 05-22-2011, 11:20 PM
Aaron-71's Avatar
Aaron-71 Aaron-71 is online now
Aaron-71 is a splendid one to beholdAaron-71 is a splendid one to beholdAaron-71 is a splendid one to beholdAaron-71 is a splendid one to beholdAaron-71 is a splendid one to beholdAaron-71 is a splendid one to behold
70's 351 Serial #?
Where the hell do I find the serial number for my 351?
I've been looking for hours now, scraping off crud and dirt from under my truck and I can't seem to find it at all.
I didn however, get the number off of the starter. That was an easy find, but nothing else!
Any help on the location?
I've heard behind the starter, but I just spent an hour with a mirror, flashlight and screwdriver, getting all the crud off the block in that location. To my surprise, ZILCH! Nada! No comprendo!
Where the hell is this #??
Here is the serial # for my starter, don't know if it helps for decoding my serial # for my block haha.
D8AF-AA-8C2B
Old 05-23-2011, 12:10 AM
Beanscoot Beanscoot is online now
Beanscoot is gaining momentum as a positive member of FTE.Beanscoot is gaining momentum as a positive member of FTE.
That number you supplied for the starter motor, D8AF-AA-8C2B, is not a serial number. It is a casting or engineering number. Being Ford, this isn't even the same as the part number, but a dealer can usually find the part number from the casting number.
Ford generally did not put serial numbers on these engines.
Old 05-23-2011, 06:43 AM
gfw1985's Avatar
gfw1985 gfw1985 is offline
Cranky Old Guy
gfw1985 is a name known to allgfw1985 is a name known to allgfw1985 is a name known to allgfw1985 is a name known to allgfw1985 is a name known to allgfw1985 is a name known to all
While it is behind the starter you will have to look straight up toward the head. There is a flat spot with the casting number and will read like the number you posted.
Can't find your engine serial number? Pikachu 1999 - 2003 7.3L Power Stroke Diesel 4 08-29-2014 02:01 PM
Serial number decode normy19 1948 - 1956 F1, F100 & Larger F-Series Trucks 4 03-05-2014 12:00 PM
serial no. location jbell110 1973 - 1979 F-100 & Larger F-Series Trucks 12 12-09-2011 08:25 PM
Serial Number Truck problems2 1973 - 1979 F-100 & Larger F-Series Trucks 8 01-02-2011 10:09 AM
47' Ton and 1/2 Serial # Decode question Person25 1947 and Older Ford Trucks 3 12-12-2010 04:22 PM
Tags
351, 70s, de, engine, find, ford, located, motor, nmero, number, serial, serie, starter, windsor, year
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
