Front door speakers
Front door speakers
Stock front speakers are about the worst junk I've ever seen in any car. They can't weigh more than a few ounces each which means the magnets are very lightweight and no conducive to quality sound at power. I installed my component Infinity Reference 2-way fronts and the difference is astounding. There's a lot more sound available in the stock system if you want to do a little bit of work.
Reverse the process to put it all back together. Shouldn't take more than 10 minutes a side.
Yes, I'm also replacing the rears as they're worse than the fronts. Probably the cheapest and best thing you can do to get significantly better sound.
A comparable speaker would be the Infinity 682.9CF which can be had for around $80 shipped online.
Here's the wiring harness if you don't want to tap into the existing wiring...these may be found cheaper elsewhere
http://www.crutchfield.com/p_1207104...s.html?tp=3097
Did you just replace the driver in the lower door, or did you replace the factory tweeter also, or did you just leave it disconnected?
In a component set, I wonder if the aftermarket tweeter would even fit in the factory location at the top corner of the door panel.
I didn't look close, but I thought in mine the only speakers in the rear door were the small tweeters up top. Are there also lower drivers in the rear doors?
I agree the OEM speakers leave quite a bit to be desired. I am just now looking into my plan of attack for upgrades. I will probably put some sort of dynamat-like material on the doors and install the Jimmi-Jammers while I have the door panels off also.
Thanks, just curious...
-Rob
-Rob
-Rob
-Rob
I replaced the 6X9 in the front doors only with a 2 way Infinity Reference series with crossover.
I haven't looked at the rears yet, but will replace them with Infinity stuff as well.
what about JL audio? If you could replace your stock 4 speakers in a crew cab, which type would they be. I have no clue what to look for. I just want to unplug the old ones and throw in new ones. I dont want to add an amp or anything. Any suggestions?
JL Audio TR570-CXi - These are what I'm looking at.
Don't want to be bossy, but can you post two links for the speakers you would pick out for me in the front and rear of the truck? Crew cab
Infinity Reference 6832cf 2-way car speakers for 5"x7" and 6"x8" openings at Crutchfield.com
You can get them a bit cheaper on ebay which is where I'll buy them, but Crutchfield gives you the wiring adapter and install stuff for your specific vehicle for free (wiring adapters are around $8 online) According to Crutchfield, the rears will accept 6X8 same as the fronts.
