94 f150 injectors not firing, ECM location
Yes, but only accessible from under the hood. Open hood look behind driver side wheel well, on the lower right firewall. There is a long thing plug with a bunch of wires going to it. That's the eec. It takes a 10mm socket to loosen the wiring harness, and then two small, I think 7/16" nuts to remove the rubber seal before the eec will slide out. You will have to remove some bolts in your inner fender well and then pry down on the fender well from the outside while sliding the eec out through the opening.
bkbarnes
04-28-2016 08:16 AM
Wildrebel69xxxx
04-26-2016 04:58 PM
morse
12-29-2014 08:40 AM
1997f350stroker
15
11-07-2010 08:39 AM
