Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2009+ F150
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
2009+ F150 Discuss the 2009, 2010 and new 2011 Ford F150 SPONSORED BY:
  #1 (permalink)
Old 05-22-2011, 09:33 AM
murph1's Avatar
murph1 murph1 is offline
Garage is empty, add now
murph1 is starting off with a positive reputation.
truck cap 3rd brake light
I am trying to hook up my 3rd brake light on my cap..its on a 2010 stx...
I have read that there is a green wire that Ford left us just for this purpose..green wire sticking out by itself labeled es-1 directly under the master cylinder..shrink tubing over the end of it
I checked the wire for power with the brake on/off...it does get power when the brake is on..
tried to pick up a temporary ground near the tailgate stiker post to verify that this will work..now I have no power on this green wire..
can't seem to find a blown fuse.
what am I missing?
should I have used the ground/black wire near the fuse box on the radiator support...it sticks out like the green one and it is labeled es-1 as well..
looked at the wiring hook up on here before I thought but searching doesn,t show anything for me..
thanks
  #2 (permalink)
Old 05-24-2011, 03:46 PM
murph1's Avatar
any ideas?
  #3 (permalink)
Old 05-24-2011, 03:48 PM
wchain wchain is offline
wchain is starting off with a positive reputation.
Does the trailer wiring relay/fuses etc have to be plugged in?
__________________
11 F150 FX4 Screw EcoBoost
11 Taurus SHO Ecoboost
03 Towncar
Gone: F250 CC Lariat V10, F250 CC Lariat PSD 4x4
  #4 (permalink)
Old 05-24-2011, 04:06 PM
murph1's Avatar
Quote:
Well, I had power on that wire only when the brake was on when I started. nothing had changed ecept that I lost power on that wire ..
I spliced into that wire and ran the wire on the ground next to the truck,at the cap,wire nutted temporarily to the brake light and tried to pick up a ground off the tailgate striker post to verify operation of the light...
must have shorted out,but cant seem to find a blown fuse...and everything works cept for power to that wire..maybe took out a relay?
looks like we still have power to the trailer pigtail...
thanks
  #5 (permalink)
Old 05-25-2011, 12:53 PM
ddrumman2004 ddrumman2004 is offline
2011 Ford F-150
ddrumman2004 is gaining momentum as a positive member of FTE.ddrumman2004 is gaining momentum as a positive member of FTE.
Sure you have a good ground? When I hooked up the third brake light on a truck cap on the 97 F 150 I just had, I had to ground the light to the frame of the truck. Just couldn't get a decent ground anywhere else.
I picked power up for that light from the third light that was original to the truck.
__________________
2012 F-150 XLT 4x4 Super Cab
2012 Mustang Convertible with 3.7 V6
2006 Yamaha 650 V Star Classic
2000 Harley XL1200 Sportster
2004 Yamaha Bruin 4x4(wife's)
  #6 (permalink)
Old 05-25-2011, 02:48 PM
countryboy69's Avatar
countryboy69 countryboy69 is offline
2011 Ford F-150
countryboy69 is starting off with a positive reputation.
It should be fuse 82 in the battery junction box, 10 amp and it is the green wire. try checking that fuse.
  #7 (permalink)
Old 05-25-2011, 05:18 PM
mrbill1943 mrbill1943 is offline
2010 Ford F-150
mrbill1943 is starting off with a positive reputation.
That wire may already be grounded
  #8 (permalink)
Old 05-26-2011, 07:56 PM
murph1's Avatar
[quote=countryboy69;10385097]It should be fuse 82 in the battery junction box, 10 amp and it is the green wire. try checking that fuse.[/quote
I looked at them all,but I am going out right now to check that one..Ipulled many and checked them with a meter instead of just a visual look..
that fuse is only for that purpose isn't it?
pulled fuse checked with meter...good fuse...then checked for power on green wire with brake on and we now have power...?
would you happen to know what the short wire that comes out of the battery box is for...it says es-1 but,it is a black wire..
thanks for your help..
Tags
3rd, black, brake, cap, connect, f150, ford, light, ranger, sale, shell, taillight, truck, virginia, wire, wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
