1948-1952 ford truck parts
#46
Category: Accessories
Price: $1
Private or Vendor Listing: Private Listing
Part fits (you may select multiples): CRX & pre '92 Civic
#49
I am looking for a right front fender for a 53-54 F1. Also a gravel pan for a 53. I would be interested in both front fenders if in good shape. Also need the V8 badge on the front grill of a 53. Does not have to be in great shape. Plan on buffing it down and painting it to match the truck. Have any of this stuff? If so can you send pics to HondaValkyrie at comcast dot net. Thanks, Rick
#50
Do you still have the "f1 front axles"? If so, what are they off of? I am looking for an axle from 1948-52. The f1 designation probably answers the question, but I am new to the old Ford truck hobby. I just bought a 47 1 Ton.
#51
I also have an 8BA flathead V8 that is complete. I pulled the heads to check for cracks and could not find any. I used 400 grit in between the valves and cylinder walls where they like to crack but did not see anything. It is not stuck. It is standard bore. It had clean oil in it. It came out of a 1950 truck. I have an extra set of heads and an extra crank for it. It needs to go. I also have a 226 flat 6 block and a 215 6 that is stuck. MAKE ME AN OFFER!!!
Thank You
#56
Here are some more parts I need to get rid of.
All are from a 54 f250.
deluxe heater - complete
ash tray
glove box door
pedal assembly
steering column
electric wipers
transmission cover
cowl vent assembly
battery cover
Make me an offer on this stuff. It is still together in the cab so if you want the whole thing let me know.
ash tray
glove box door
pedal assembly
steering column
electric wipers
transmission cover
cowl vent assembly
battery cover
#60
Do you have original dome light in your truck if so could you send picture to ac13387@dslextreme.com
I have a lead on one but I don't know what it looks like
