1948-1952 ford truck parts
Category: Accessories
Price: $1
Private or Vendor Listing: Private Listing
Part fits (you may select multiples): CRX & pre '92 Civic
1949 f6 two speed rear axle with springs
2-48-52 f5 f6 front axles
1955 f600 electric two speed
1950 f4 rear axle with 4 14 inch rims
1950 f4 front axle with 2 14 inch rims
2 f1 front axles
a bunch of 20 in split rims
a grain cylinder hoist and pump WORKS i was using it last year
***Please make me an offer on this stuff. I am not wanting a fortune at least scrap price. I would love to see someone get some use out of it. Space is getting tight.
I also have-
2 48-52 bench seats (no rust)
1954 complete cab sitting on an f250 frame with 8ft bed (some rust in the front corners, doors are nice excellent top very fixable)
2 stubby running boards 48-52 (rust free)
1 48-52 gas tank (not full of rust)
1 3 speed floor shift (nice inside)
a lot of 4 speed non synchronized parts
48-52 inner fenders
1 48-52 ash tray
1 53-55 ash tray
1 56 ash tray
I have a bunch of other stuff if you do not see what you need PM me.
I also have an 8BA flathead V8 that is complete. I pulled the heads to check for cracks and could not find any. I used 400 grit in between the valves and cylinder walls where they like to crack but did not see anything. It is not stuck. It is standard bore. It had clean oil in it. It came out of a 1950 truck. I have an extra set of heads and an extra crank for it. It needs to go. I also have a 226 flat 6 block and a 215 6 that is stuck. MAKE ME AN OFFER!!!
Hi, I would like the gas tank & the
48-52 inner fenders..Before I make an offer would u happen to have a box for a 48 F1 and back fenders ? and any other parts for a 1948 F1 ?
Thxs,
Cody
Thxs,
Cody
I do not have a good bed or fenders, I am actually looking for a 48-50 right rear!! I have a lot of other parts for the 48-50s. I have some hoods, but no fenders, a lot of in cab parts.
I do still have the running boards they are the short ones similar to what the panel trucks used. I have a very nice set that is completely rust free. 300 for the pair. It will fit your f1, but I think you need different mounts or modify the ones you have. I may have some mounts and If I do I will throw them in.
