1948-1952 ford truck parts - Page 9 - Ford Truck Enthusiasts Forums
Ford Truck Parts for Sale Ford Truck related Parts and Accessories for sale
Parts Search
Keyword:
Category:
Price:
Private or Vendor Listing:
Location (State):
Item Condition:
Cars Search
Keyword:
Year:
(Range)
Make:
Model:
Price:
Mileage:
Location (State):
  #121
Old 10-11-2012, 09:54 AM
fifty-two_f1's Avatar
fifty-two_f1 fifty-two_f1 is offline
fifty-two_f1 is starting off with a positive reputation.
Category: Accessories
Price: $1
Private or Vendor Listing: Private Listing
Item Condition: Used
Part fits:: 1948-1960
I am more than happy to help. Let me know when you want to come get it. I am home on most weekends (im at purdue) but I can get it set out and ready and have dad load you if I am not home so just let me know. My # is 765-635-3830 call or text.
  #122
Old 10-14-2012, 01:05 AM
Samsn4's Avatar
Samsn4 Samsn4 is offline
Samsn4 is gaining momentum as a positive member of FTE.
I'm looking for an intake for a 300 straight 6, and a rear end, preferably Dana but, do you still have any two speeds?
  #123
Old 10-14-2012, 04:47 PM
I do not have an intake for a 300. Although I think i have one for a 240 which should bolt up but I dont know if you want that or not. As far as danas, I think I have one 3.92 ratio dana 44 and i still have the 2 speed. (someone else is interested in it, but If he decides that he does not want it ill post it)
  #124
Old 10-15-2012, 09:29 AM
The Horvaths The Horvaths is offline
The Horvaths has a good reputation on FTE.The Horvaths has a good reputation on FTE.The Horvaths has a good reputation on FTE.
My son and I need the emergency brake system (lever to shoes, all of it!) to fit our 1955 F500 with a 4syn transmission. It has the "drum" (band?) mounted on the tail shaft but that's all. We'll even need the brackets. Somebody pulled the rest of it long ago. Do you happen to have this set-up available?
  #125
Old 10-15-2012, 03:30 PM
I am sure I have all the parts you need. I am unsure of the condition though. I am at Purdue university through the week. I can check on the weekend. What other parts do you have?? I parted out a 55 f600 some years ago and still have some parts left over.
  #126
Old 10-15-2012, 08:19 PM
Quote:
OK, get my terminology right here:
Our vehicle has only the drum. No band, no nothing else. What looks to have been a bracket was cut off of the transmission side with a torch. Our drum is pitted but may be sericeable. I'll try to send a PM with a list. No big hurry, many other projects prior to our state safety inspection.
  #127
Old 10-15-2012, 09:22 PM
Okay, let me know as soon as you can that way I can take a look.
  #128
Old 10-20-2012, 07:57 PM
49 panel truck 49 panel truck is offline
49 panel truck is starting off with a positive reputation.
I am restoring a 49 f1 panel truck. The rear fenders are rusted out and i was thinking you might have some or knowing where i can get some.
Nick
  #129
Old 10-21-2012, 07:27 AM
cstempert's Avatar
cstempert cstempert is offline
cstempert is starting off with a positive reputation.
Nick
Pretty common problem. There are no repro rear paneltruck anything available, except rubber and tail lights. Luckily, most of the metal back there is fairly flat or only curves in one direction (as opposed to compound curved like the roof). If you find a paneltruck with good rear sheetmetal, use that one!
I've been on and off patching my 50 together and you will find more as you start removing things, especially in the floor and door areas, but don't give up on it.
How are the rear doors? These too, are really hard to come by.
If you are updating the interior, I am still on the look out for a passenger jump seat, if you have it as it was an option. If you aren't using the driver seat either, pm me, I may take it off your hands.
Good luck and take lots of pics, helps with the rebuild and keeps ooglers on the board something to ponder.
Chris
Quote:
Nick
  #130
Old 10-22-2012, 08:04 PM
Samsn4's Avatar
Sent a pm,
I am building a 53 F250, long bed, 8lug, 300 I6, C6
I've had to cut budget so instead of $400 for intake and carb, i'm hoping for under $200, does the intake include a carb?
For the rear end, i would like to get a gear ratio of the mid 3's to retain optimal gas mileage. What is the width on the dana 44? and the gearing on the two speed?
Thanks
  #131
Old 10-30-2012, 10:36 PM
I just bought an f250 with a 300 6 that I plan on working on. So whatever left over parts I have we can deal on them. What year is your 300?
  #132
Old 10-30-2012, 11:18 PM
Samsn4's Avatar
Not sure the exact, but the cast code on the passenger side of the block indicates that it's a 1987. I got it from a 1989-97 style truck, f150.
  #133
Old 10-30-2012, 11:21 PM
So you want to go away from fuel injection?
  #134
Old 10-31-2012, 12:04 AM
Samsn4's Avatar
Correct, No EFI.
  #135
Old 10-31-2012, 12:19 AM
there is a 300 6 in an 80-86 truck in the salvage yard that I went to today. I can ask the guy what he wants for the manifold(s) and carb
Tags
19481952, 1952, 52, aftermarket, catalogue, chassis, conversion, diesel, f1, f4, ford, gauges, part, parts, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
1948-50,51,52 trucks parts V8,226 F1-f7(&motors) Cody_1948 Ford Truck Parts for Sale 13 12-10-2015 06:46 AM
‘48-‘52 Ford F-6 C.O.E. build assistance & advice CruzerDog 1948 - 1956 F1, F100 & Larger F-Series Trucks 10 03-05-2014 09:06 PM
48-52 hubs fifty-two_f1 1948 - 1956 F1, F100 & Larger F-Series Trucks 4 06-08-2013 01:00 PM
Left-over parts for sale, 48/52 Ford stuff jimprowse 1948 - 1956 F1, F100 & Larger F-Series Trucks 5 07-25-2011 08:32 PM
