Crank pulley question??????
Old 05-21-2011, 06:15 PM
Green Griffin 420's Avatar
Green Griffin 420
Green Griffin 420 is offline
I'm putting underdrives on the 5.0 and before I get started I thought I'd ask this question.
Are the threads reverse on the crank pulley?
Old 05-21-2011, 06:17 PM
86F150302's Avatar
86F150302
86F150302 is offline
Nope.
blah blah 10 characters min..
Old 05-21-2011, 06:19 PM
Green Griffin 420
Green Griffin 420
Oh and thanks.
Old 05-21-2011, 06:31 PM
86F150302's Avatar
86F150302
No problem. Ive had mine off quite a few times.
Old 05-23-2011, 09:26 AM
Green Griffin 420
Well I didn't get them off. I'm either going to have to get a much shorter impact wrench or pull my radiator to get the pulley off.
Any tips 86F150302?
Old 05-23-2011, 09:38 AM
bashby's Avatar
bashby
bashby is offline
put a long ratchet on it, butt it up against the frame and crank the engine
Old 05-23-2011, 10:47 AM
Green Griffin 420
That sounds a little on the dangerous side. I don't have a ratchet that long either. I guess I could use a piece of pipe for a breaker bar.
Old 05-23-2011, 11:12 AM
cj06's Avatar
cj06
cj06 is offline
MAKE SURE YOU LOCK THE RATCHET ON THE CORRECT SIDE OF THE FRAME !
Old 05-23-2011, 11:27 AM
bashby's Avatar
bashby
bashby is offline
Its safer with a ratchet than a breaker bar in case it kicks back the ratchet will just spin. I've done it countless times and havent broken any car or body parts yet! Use a cheater pipe on a ratchet like you were saying.
Old 05-23-2011, 11:36 AM
Green Griffin 420
Do you get under it and hold the ratchet in place and have someone bump the starter?
Old 05-23-2011, 11:42 AM
cj06's Avatar
cj06
cj06 is offline
if you have a remote starter switch then that works best , what ever you do pull the coil wire off so it wont start ! and if you hold the ratchet hold it with a open hand !
Old 05-23-2011, 01:12 PM
bashby's Avatar
bashby
bashby is offline
I hold it and have someone bump it when I can so it doesnt kisck off and hit the rad or something. If theres no one around to help I try to prop it up against something.
Old 05-23-2011, 01:19 PM
Green Griffin 420
I guess I'll give it a shot. I'll probably trip the roll over relay to shut off the fuel to keep it from running.
Old 05-23-2011, 01:30 PM
bashby's Avatar
bashby
bashby is offline
just pll the coil wire, killing the fuel pump might let it run for a split second with residual pressure in the lines.
Quick Reply: Crank pulley question??????
