How many 2wd are out there - Ford Truck Enthusiasts Forums
Old 05-21-2011, 12:30 AM
cherrybomb37's Avatar
cherrybomb37 cherrybomb37 is offline
cherrybomb37 is starting off with a positive reputation.
I have a 1989 F150 2wd and I wana know how many of you guys are running around with 2 wd half tons 3/4 tons and 1 ton older fords?
Old 05-21-2011, 12:34 AM
SideWinder4.9l's Avatar
SideWinder4.9l SideWinder4.9l is offline
SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.
Mine...Info in the sig...
Old 05-21-2011, 12:35 AM
BIGskinny BIGskinny is offline
BIGskinny is starting off with a positive reputation.
90 f150 2wd
<a href="http://s224.photobucket.com/albums/dd66/bigbubba0/?action=view&amp;current=picoftruck1.png" target="_blank"><img src="http://i224.photobucket.com/albums/dd66/bigbubba0/picoftruck1.png" border="0" alt="Photobucket"></a>
<a href="http://s224.photobucket.com/albums/dd66/bigbubba0/?action=view&amp;current=picoftruck.png" target="_blank"><img src="http://i224.photobucket.com/albums/dd66/bigbubba0/picoftruck.png" border="0" alt="Photobucket"></a>
Old 05-21-2011, 12:40 AM
ryito1122334455's Avatar
ryito1122334455 ryito1122334455 is offline
ryito1122334455 is starting off with a positive reputation.
92 2wd, didnt want one at first, being in ohio winters, but suprisingly dosent do bad at all in the snow, especially with some weight in tyhe back, and knowing how to drive in snow always helps. im loving the 2wd fuel economy tho, i guess it has its up sides
Old 05-21-2011, 02:32 AM
zxwut?'s Avatar
zxwut? zxwut? is offline
zxwut? is gaining momentum as a positive member of FTE.zxwut? is gaining momentum as a positive member of FTE.
I only made that mistake once
Old 05-21-2011, 02:50 AM
Quote:
What would that mistake be?
Old 05-21-2011, 03:28 AM
SouthernBlues's Avatar
SouthernBlues SouthernBlues is offline
SouthernBlues has a good reputation on FTE.SouthernBlues has a good reputation on FTE.SouthernBlues has a good reputation on FTE.
I have a 95 2wd
Old 05-21-2011, 05:15 AM
zxwut?'s Avatar
Quote:
Buying a 2wd. Keep up bro.
Old 05-21-2011, 05:56 AM
DBGrif91's Avatar
DBGrif91 DBGrif91 is offline
DBGrif91 is gaining momentum as a positive member of FTE.DBGrif91 is gaining momentum as a positive member of FTE.
1991 5.8
Bought it from my grandfather about 2-2.5 years ago, and now that he's passed on I would like to put a little work into it and shine it up a bit. That probably won't be for a little while tho.
Old 05-21-2011, 10:13 AM
Duct Tape Racing's Avatar
Duct Tape Racing Duct Tape Racing is offline
Duct Tape Racing is gaining momentum as a positive member of FTE.
I Love my 2wd!!!! Bought it when i was 14 for $500! 300/6 5 speed
Uploaded with ImageShack.us
Old 05-21-2011, 11:40 AM
Where I live man there's no point of a 4wd. Soon as u hit the woods seems like helis over u and ranch and groves behind you. But I do agree it is nice to have the two extra pullin tires if u need to use it. I'll own a 4wd soon loo
Old 05-22-2011, 06:52 PM
ososlow's Avatar
ososlow ososlow is offline
ososlow is starting off with a positive reputation.
My 93
Wanted a 4x4, but couldn't find what I wanted. This was cheap and had the drive train I wanted, so I bought it.
I'm glad I did. Cheap to insure, tiny bit better on gas (compared to my dad's identical 93 4x4) and no temptation to go out wheeling it and break things.
It's great in snow too. I bought the best tires I could afford and threw 5-600lbs of cement in the back. I can go nearly anywhere.
Old 05-22-2011, 06:58 PM
tpcgregsheh tpcgregsheh is offline
tpcgregsheh is starting off with a positive reputation.
Check my signature. I live in California, there really is no need for 4x4
Old 05-23-2011, 05:27 AM
ILLXJ ILLXJ is offline
ILLXJ is starting off with a positive reputation.
Mine:
If I need 4wd, I use this:
JIM.
Old 05-23-2011, 11:07 AM
hivoltj's Avatar
hivoltj hivoltj is offline
hivoltj is gaining momentum as a positive member of FTE.
2 here, '94 Lightning, and '92 F-150 RCLB. They get around fine in the winter, except the '92 has ****ty tires!
What is it? MarkV 1947 and Older Ford Trucks 11 02-28-2017 05:31 PM
Will a 3/4 ton spindle bolt onto a 1/2 ton I beam? tonymontanna1983 1973 - 1979 F-100 & Larger F-Series Trucks 3 08-21-2016 10:01 PM
How many 1 Tons pickups were made in 1946?? jdhudall 1947 and Older Ford Trucks 27 01-28-2013 02:55 PM
XLT 1/2-Ton vs Bighorn 1500 Hemi Jag Red 54 2009 - 2014 F150 13 09-17-2011 09:36 PM
What Ton jack to i need for superduty ? browntown3 1999 to 2016 Super Duty 18 11-26-2008 09:13 PM
Tags
2wd, ford, sandbags, winter
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
