Coil wiring - Ford Truck Enthusiasts Forums
Coil wiring
Old 05-20-2011, 08:19 PM
mic687 mic687 is offline
mic687 is starting off with a positive reputation.
Coil wiring
Guy's I am replacing the coil on my 1949 F6 with a flathead 239. My old coil is in bad shape and has bat on one hook up and I can not read the other. My new coil has + on one connection and - on the other which one goes to the distributor the +or -. Ok after I sent this I found the below info on a google search. Is this correct to the best of your collective knowledge.
COIL CONNECTIONS:
On a positive ground system, the feed from the ignition switch is to connect to the negative marked terminal on the coil. If connected wrong, the coil output will be about 14% less at idle. This percent of reduced coil output increases to as much as 30% as rpm’s increase. The decreased coil output causes hard starting and poor performance.
Old 05-20-2011, 08:31 PM
ALBUQ F-1's Avatar
ALBUQ F-1 ALBUQ F-1 is online now
postin' fool
ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.
Is your truck still 6v Pos. ground? If so, the (+) terminal on the new coil goes to the distributor (points), the (-) goes to ignition power.
Old 05-20-2011, 08:46 PM
Quote:
Yes it is still pos ground 6v until I get it running then I want to switch it to 12v. Thank you for the reply I was leaning that way but was not sure and was certain I was not the first to incounter this problem again thanks for the quick reply.
Old 05-20-2011, 10:21 PM
ssj7kids's Avatar
ssj7kids ssj7kids is offline
ssj7kids is gaining momentum as a positive member of FTE.ssj7kids is gaining momentum as a positive member of FTE.
WoW, this positive ground thing is messin with my head....
Timely question....
THANKS
Old 06-10-2011, 11:08 PM
bobsjoint420's Avatar
bobsjoint420 bobsjoint420 is offline
bobsjoint420 is starting off with a positive reputation.
I myself changed the coil in my 49 f3 with the flathead, after i changed it it worked for about 4 blocks and quit, now i replaced the points condenser rotor and still nothing so now i'm going to replace the coil again and see what happens i have no idea why the new coil would only work for about 4 blocks of driving. I also tried getting a new cap from oriellys and the new cap they gave me snapped the new rotor and the old one, so now i'm going to have to find a cap someplace else.
Old 06-10-2011, 11:25 PM
ALBUQ F-1's Avatar
postin' fool
Bob, I wonder if your distributor has a lot of slop in the upper bushing, allowing the rotor to wobble so much it hits the posts in the cap. Before I went thru another cap, I think I'd pull the dizzy and check it out. Then put a new cap on it and spin it by hand, see if it's hitting again.
Old 06-11-2011, 11:42 AM
ssj7kids's Avatar
Just a question...
My coil is marked with "Bat" and "Dist"
For positive ground, does this get reversed?
Since "Distributor" goes through the points "to ground".... Should the terminal marked "Dist" be connected to the "battery" which would be the Negative terminal?
I don't know why this is so hard for me to understand... I "get" electricity...
Old 06-11-2011, 12:09 PM
ALBUQ F-1's Avatar
postin' fool
Quote:
Originally Posted by ssj7kids View Post
Just a question...
Nope, Bat still goes to power, Dist still goes to points. One side of the coil secondary winding is connected to ground via the case. You want the Dist connection to go to the same ground.
Old 06-11-2011, 12:21 PM
ssj7kids's Avatar
Ross,
Thanks... something so simple....
Old 06-11-2011, 05:45 PM
jb50F1's Avatar
jb50F1 jb50F1 is offline
jb50F1 is starting off with a positive reputation.
You might want to check the voltage and amperage going to the coil. It should have about 6.3 or 6.4 volts to the coil with 3 to 7 amps. If less than that, particularly amps, look for dirty or loose connections between the coil and the ignition switch in the primary circuit.
Question on Coil - 67 F100/ranger hombre292 1967 - 1972 F-100 & Larger F-Series Trucks 2 10-18-2014 04:34 PM
Installed Headlamp Relays w/ Pics quakerj 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 7 01-27-2014 08:59 AM
Performance canister coils with Duraspark II? FordFETruck 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 85 10-06-2013 01:54 AM
Coil Positive extra wire? Screamin T/A 1973 - 1979 F-100 & Larger F-Series Trucks 5 02-01-2012 09:09 PM
coil question jstaguy24 FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 28 04-14-2011 10:58 AM
Tags
1961, 69, 96, coil, electric, f100, ford, hook, injector, lightning, picture, setup, truck, van, wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
