2003 Expedition Humming/Whining noise 40-50 mph - Ford Truck Enthusiasts Forums
1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
Old 05-20-2011, 04:21 PM
ctaylor45 ctaylor45 is offline
ctaylor45 is starting off with a positive reputation.
Hey guys,
I just bought my first ford truck, a 2003 Expedition Eddie Bauer 2x4 with the 5.4L engine. It has 39.7K miles. I didnt notice the noise I am describing on the test drive, I noticed it when I brought the truck home with me. As soon as I hit 40 mph, I get a whining noise that sounds like its coming from the front end, and stops at about 50 mph. Ive only heard it at those speeds. Ive searched the board, but havent found a pinpoint thread as to the symptoms I have. Ive seen various differential and transmission threads, but not sure which one mine falls under. what do you guys think it could be? will I mess anything up if I dont get it checked out? any kind of powertrain warranty left on my 03 with lows miles? let me know what you guys think, thank you for the help!
Chris
Old 05-21-2011, 03:22 AM
Moto Mel's Avatar
Moto Mel Moto Mel is offline
Moto Mel has a great reputation on FTE.Moto Mel has a great reputation on FTE.Moto Mel has a great reputation on FTE.Moto Mel has a great reputation on FTE.Moto Mel has a great reputation on FTE.
Most likely there is no warrantee left but the dealer may help you out, if you bought from a dealer. If not, it's on you. If it's a high pitched whine that is in synch with the engine it could be the front pump in the trans and it could last a very long time without problems or it could go out at any time.
Old 05-21-2011, 07:42 AM
ScottyDsntKnow ScottyDsntKnow is offline
ScottyDsntKnow is gaining momentum as a positive member of FTE.ScottyDsntKnow is gaining momentum as a positive member of FTE.
Well if you just bought it you should at least have a 1k 30 day warranty of some sort from a dealer. If you got it from a 3rd party or a shyster dealer then you'll have to have it diagnosed.
I'm having driveline noise issues from mine that I just got 3 weeks ago that didn't start until a few days after I got it which is my luck of course...
What I'm going to do, hopefully this weekend, is to do ALL the fluids in the diffs (plus add friction modifier), transfer case, trans and torque converter. Then U joints, and then maybe half shafts which is all preventative maintenance anyway on an 8 yr old vehicle. I know yours has super low miles but sometimes the ones that sit a lot are worse off than ones that have been driven normally.
I'd start with the fluid changes at least, you should be doing them all anyway since nobody ever really knows wth kind of fluids any previous owners/dealers used. I should have already done mine but I've only put 500ish miles on it and I've been ridiculously busy. But yeah I would start with fluids.
The good news is that even if, god forbid, it is the trans, Ford truck transmissions are ridiculously cheap for a used low mileage one and it is easy to upgrade the 03/04 trucks to the newer 4R75E tranny if it comes to that.
Old 05-24-2011, 07:44 PM
I bought the truck from a private seller. so is this more likely a tranny issue or a diferential issue? anybody else with experiences on this issue?
Old 05-24-2011, 07:55 PM
expy37at expy37at is offline
expy37at is starting off with a positive reputation.
Just remembered I had a whining issue on the '01 and it was coming from the rearend.
I checked the preload and the folks at the factory never set it correctly.
Made a couple tools, got the crush washer and some other stuff and did the job to specs.
It's been fine since and ~1/2 of the 106,000 mileage has been towing.
Old 05-24-2011, 09:32 PM
pdqford pdqford is offline
pdqford has a good reputation on FTE.pdqford has a good reputation on FTE.
Quote:
How 'bout if you just rev it up to those rpms in park or neutral - still get the whining noise?
Old 11-26-2013, 07:18 PM
thundercraft123 thundercraft123 is offline
thundercraft123 is starting off with a positive reputation.
I have the same humming issue between 40 and 50 mph on a 2003 Expedition. Never found the cause or a fix.
Old 11-26-2013, 09:58 PM
alloro alloro is online now
alloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to behold
Could just be the tires. Swap the tires front to back and see if the noise changes.
Old 11-27-2013, 05:27 AM
Thanks for your suggestion but I tried a tire rotation and it had no effect on the noise.
Old 11-27-2013, 08:23 AM
bumparker bumparker is offline
bumparker is starting off with a positive reputation.
Possibly a front hub. Take note when you are driving and hear the humming, does it change or disappear when the suspension loads and unloads (going over a dip), is there a change when turning slightly to the right or the left. If you get this type of variation in the humming then it is possibly one of your front hubs.
I had front end humming on my 2003 that did not change with tire rotation by I noticed the humming would stop momentarily when the suspension unloaded. I eventually changed both front hubs but the first one started humming about 80k.
Front hubs are easy to change, they cost $125+ depending on manufacturer.
Old 11-27-2013, 09:43 AM
Humming
I don't think it changes when unloaded but I'll try it and make sure. It does stop when I let off the gas though.
Thanks
Old 11-27-2013, 10:58 AM
Quote:
That could make it an engine noise. Does the humming pitch follow engine speed or vehicle speed?
Old 11-27-2013, 11:34 AM
The pitch doesn't really vary but smetimes the volume of the humming does. It's weird. When I hit 40 it starts and stops at about 50. Thanks
I noticed Ctaylor45 has the same probrem. I'm new to the site and don't know how to
ask him.
Old 11-27-2013, 12:30 PM
droldsmorland's Avatar
droldsmorland droldsmorland is offline
droldsmorland has a good reputation on FTE.droldsmorland has a good reputation on FTE.
Not sure that your not describing the "wind under the windshield trim" issue seen on the newer trucks? Does it sound mechanical or other? Do a search under my name in the SD section and look at the "wind noise" threads. Could just be that simple though it usually occurs at higher speeds with head winds but can hurt to rule it out. Its simple and cheap to fix.
Old 11-27-2013, 02:23 PM
I noticed Ctaylor45 has the same probrem. I'm new to the site and don't know how to ask him.
Click here to send him a PM: http://www.ford-trucks.com/forums/pr...newpm&u=606708
Rear End Whine F150MUTT 2015+ F150 7 01-20-2017 11:21 AM
2004 Expedition whistle/whine noise??? RSCHAP1 1997-2006 Expedition & Navigator 35 11-28-2013 03:01 AM
Whining noise - Idler pulley? nsaikia 2004 - 2008 F150 6 06-16-2013 09:36 AM
transfer case/transmission noise bigunit54 2004 - 2008 F150 8 06-11-2012 08:03 PM
2003 F150 Supercrew whine when turning from rear end coolguy1419 1997 - 2003 F150 5 05-08-2012 10:07 PM
Tags
2003, 2004, 2006, 50, area, belt, expedition, f150, ford, front, humming, loud, make, mph, noise, sound, whining
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
