2WD Front wheel bearings - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Old 05-20-2011, 11:28 AM
C. Lee Colbert's Avatar
C. Lee Colbert C. Lee Colbert is offline
C. Lee Colbert is starting off with a positive reputation.
I need to replace my front wheel bearings on a 2WD Ranger...any suggestions?
Old 05-20-2011, 12:45 PM
g_k50 g_k50 is offline
g_k50 is gaining momentum as a positive member of FTE.g_k50 is gaining momentum as a positive member of FTE.
I just did mine on my 1999. Scheduled maintanence for the 1999 calls for inspect and adjust every 30,000, lubricate at 120,000. Pretty easy to do, no special tools required, use Ford parts only.
Old 05-20-2011, 12:49 PM
Rangerman Stan Rangerman Stan is offline
Rangerman Stan is starting off with a positive reputation.
Might as well replace the grease seals too, since they have to come out anyway. But maybe that was already on your list. How many miles on your "97"? If you don't have a torque wrench to set the bearing pre-load you can do this: To set the wheel bearing torque WITHOUT the torque wrench, just tighten the adjusting nut very snug to seat the inner and outer wheel bearings on the spindle; (making sure they are PACKED with fresh grease first) and then back off on the adjusting NUT until the wheel spins freely with no play in it. Put the nut-lock on and the cotter pin back in and you're set.
Old 05-20-2011, 02:14 PM
Hank85713 Hank85713 is offline
Hank85713 is gaining momentum as a positive member of FTE.
I dont know about using ford only bearings, just go to a bearing house and get some good ones along with the seals. will be a lot cheaper, but if you take care of the bearings even those from a parts house will last. I have 300K+ on my 94 and got the bearing at napa or from checkers cant remember! Anyhow the PIA is to change the races if/when you do R&R the bearings.
Old 05-20-2011, 07:36 PM
03 Maz B23 03 Maz B23 is offline
03 Maz B23 is gaining momentum as a positive member of FTE.
If you get the bearings from a Napa with a machine shop they can turn rotors and install the new bearings/races and repack with grease. Only thing you need to do is reinstall em. Not sure of the additional cost but money well spent for making the job easier.
Old 07-03-2011, 01:32 AM
I ended up bringing it to a shop near my house, & good thing too...there was a lot more work needed then I could do myself. But it is all fixed up now & ready to go!
2010 2wd wheel bearing noise 72GTS Explorer, Sport Trac, Mountaineer & Aviator 0 06-15-2016 10:23 PM
2wd front wheel bearings? bigdaddyII 2004 - 2008 F150 8 04-13-2011 05:15 PM
2wd wheel bearing torque specs johnsteffy 1994.5 - 1997 7.3L Power Stroke Diesel 3 09-23-2010 11:21 AM
2000 X front wheel bearing ? TransplantX Excursion - King of SUVs 3 12-30-2009 07:55 PM
Wheel Bearings on 2007 2wd aquaholic2 2004 - 2008 F150 5 09-26-2009 11:44 PM
Tags
07, 1999, 2001, 2wd, 50, adjustment, bearing, big, f150, f250, ford, front, ranger, repack, replace, wheel, wheels
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
