beeping sounds - Ford Truck Enthusiasts Forums
beeping sounds
Old 05-20-2011, 06:37 AM
djsour djsour is offline
djsour is starting off with a positive reputation.
beeping sounds
my 1994 F150 has just started to do a seris of short beeps when i turn the ignition on doews about 4-5 short beeps pauses and starts over again everything is fine on truck don't understand it's coming from under dashboard any help debbie
Old 05-20-2011, 09:00 AM
White Max's Avatar
White Max White Max is offline
White Max has a good reputation on FTE.White Max has a good reputation on FTE.
Does the airbag light illuminate when you turn the key to "ON"? That sounds like the warning beep to tell you that the airbag light bulb has burnt out.
Bleepin' beepin' Rogue_Wulff Ranger & B-Series 6 03-29-2011 11:33 AM
2010 SD Factory Remote Start quit - Horn beeps 4 times dave3406 1999 to 2016 Super Duty 0 02-16-2011 05:18 PM
Beep Beep Beep Flip4ford Kansas Chapter 13 12-31-2008 01:09 PM
Beep Beep MAKO314 North Carolina Chapter 6 09-07-2006 09:08 PM
Explorer - 5 short beeps every 20 seconds or so! bothersome Explorer, Sport Trac, Mountaineer & Aviator 6 12-17-2003 03:49 PM
Tags
1994, 1995, beeping, beeps, econoline, f150, f250, ford, sound, sounds, starts, times, turn
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
