tips on fitting Tugger HD2 kit ?? - Ford Truck Enthusiasts Forums
Old 05-19-2011, 05:33 AM
Viper2F350dually Viper2F350dually is offline
Viper2F350dually is starting off with a positive reputation.
Since the leaking seal issue on my early 99
(see http://www.ford-trucks.com/forums/10...-stranded.html )
I've ordered replacement seal kit, TransGo Tugger HD2, Tru-cool LPD4739 MAX and the trans temp gauge.
Truck is going to a transmission place (but not a USA vehicle specialist) so looking for any tips/guides when fitting the Tugger kit.
I'm UK based, so although the shop has done a few Rams, etc the F350 is not something they have worked on.
I've seen the 30 minute vid on TransGo site ref valve body BUT I'm thinking more about the other stuff that comes in the kit, not that I know what else there is???
Ideally I wanted a uprated/modified trans pump & possibly a VB, but after trying to contact a well known 4R100 trans guy I finally gave up chasing and waiting and generally being fobbed off with Bull-shine so have what I have.
I'm on a budget, I know budget and 4R100 repairs don't gel too well but hey, I think what I have will of course stop the leaking when hot and the TRU-COOL will keep temps down anyway
Old 05-19-2011, 09:31 AM
Izzy351's Avatar
Izzy351 Izzy351 is offline
Izzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud of
It's not that bad of a job -- are they doing all the work? I did mine easily in half a day in my driveway taking my sweet time, so they should be able to handle this. I did all the mods in the VBs, but since my trans wasn't out, I didn't to the pump mods. Since yours is coming out, I'd do all those mods in the instructions. It looks really complicated, but the instructions do work. Just go one step at a time. Don't forget the electrical connection on the top by the exhaust -- since they're pulling it, it shouldn't be an issue. But doing this with the trans in the truck, you have to KNOW that's there and unplug it before removing the solenoid pack...
Old 05-19-2011, 09:43 AM
mueckster's Avatar
mueckster mueckster is online now
aka Redneck Wrencher
mueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputation
The pump mods are just as easy as the valve body mods. Once the pump is out, it's just a matter of swapping some springs and valves. I chose to add the TransGo 4R100 LU (on-off TC lock valve) when I modded the pump. It gives the TC lock up a firmer engagement that feels more like an additional shift.
Be sure and change the bushings in the pump, along with the seal, for added measure.
Old 05-19-2011, 11:29 AM
SpringerPop's Avatar
SpringerPop SpringerPop is offline
Too old to be too smart..
SpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputation
The two pump case halves need to be perfectly aligned when putting it back together, which is best done with a band clamp run all the way around the pump before torquing the fasteners.
Be sure they use a TORQUE WRENCH on EVERYTHING!!!
Pop
Old 05-19-2011, 11:43 AM
mueckster's Avatar
Pop
Good point, Pop!
Old 05-19-2011, 11:48 AM
Heck, I think I learned that from YOU!!
Pop
Old 05-19-2011, 12:02 PM
Shake-N-Bake's Avatar
Shake-N-Bake Shake-N-Bake is offline
Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.
I've got nothing to add other than I am going to follow this thread in hopes I can learn more about these transmissions. Hopefully we'll get some pictures of the build.
The TC Lock up valve is pretty nice. My wife's truck has the HD 4R100 and there is a big difference between how the TC locks up on my truck compared to hers. Does that valve come in the Tugger kit or does it have to be ordered separately like the 3 or 4 coast clutch?
If there ever is a time when the three of you guys are going to be at an event such as RRW and you want to do a trans build....I am going to book my travel plans early because I don't want to miss that.
Old 05-19-2011, 12:51 PM
Izzy351's Avatar
The TC mods come with the Tugger, Greg.
Old 05-19-2011, 01:11 PM
A big thanks for them tips so far, I'll be copying it off for the trans guys to take note.
Sadly I'll not be there to take photos, but they maybe willing to help and supply?
These guys will be fitting everything as I'm pretty naff at tech stuff and WILL break stuff
Tugger kit brought is
TRANSGO E4OD 4R100 REPROGRAMMING KIT 4R100-HD2 TUGGER on eBay (end time 21-May-11 18:58:26 BST)
Old 05-19-2011, 10:39 PM
mueckster's Avatar
The lock up valve does not come in the kit and is purchased separately. I also replaced all 3 aluminum regulator valves in the accumulator valve body with steel versions to prevent sticking.
Old 05-20-2011, 08:04 PM
Yeah I didn't think it came with lock up valve.
The valve upgrades sound a good idea, but too late for me, this is the downside of living in England with a Heavy duty truck, total and utter lack of regular parts supply let alone custom/aftermarket stuff
Old 05-20-2011, 08:41 PM
mueckster's Avatar
The steel valves can be done later by dropping the pan and accumulator VB.
Old 08-12-2014, 06:02 PM
Rock269 Rock269 is offline
Rock269 is starting off with a positive reputation.
Did just doing the VB mods work for you?
I'm not going to remove the trans. either. I have a soft 2-3 shift. I'm just wondering if I do the VB mods only if this should help my problem at all? I have the complete tugger kit but I'm going to hold off on the pump mods until I can remove the trans. It appears that everything in the Tugger mod comes with the HD and shift kit plus a little more. Thanks in advance. Greg
'96 F-150 E4OD Issues IJRoorda Clutch, Transmission, Differential, Axle & Transfer Case 17 05-09-2012 09:42 AM
Transgo Tugger Opinions barthel 1999 to 2016 Super Duty 5 08-13-2011 04:22 PM
Got TruCool,Transgo Tugger,new pump seal intalled Buicksx2 1999 - 2003 7.3L Power Stroke Diesel 6 07-24-2011 04:15 PM
Trans test port for temp reading but.... Viper2F350dually 1999 - 2003 7.3L Power Stroke Diesel 17 06-28-2011 02:33 PM
Aux Trans Cooler Question JQ Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion 3 03-14-2005 11:16 AM
Tags
4r100, 4r100hd2, 4r100lu, difference, hd2, instructions, kit, lock, mod, mods, overhaul, pump, tips, transgo, tugger
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
