Heater core replacement - Ford Truck Enthusiasts Forums
Old 05-19-2011, 12:14 AM
Suppoko Suppoko is offline
Suppoko is starting off with a positive reputation.
I started smelling coolant in the vents when the heat/air was on and the inside of the windshield frosted over late in the winter. I took it to a shop they said it was the heater core and it would cost 900 to fix, I don't know much but I thought that was pretty damned high. Is this something I can do on my own or am I going to have to pay the 900?
Old 05-19-2011, 07:00 AM
b4hntn b4hntn is offline
b4hntn is gaining momentum as a positive member of FTE.b4hntn is gaining momentum as a positive member of FTE.
You now know not to take anything to that shop again.
Not seeing the year in you signature, I'll tell you the 1992 + are easy. Remove the glove box. Remove about six screws off the heater box cover. Disconnect the hoses of course and it comes right out. Put some RTV around the new tubing at the firewall to seal it.
Old 05-19-2011, 08:57 AM
Sorry, it's a 96 351w EB edition
Old 05-19-2011, 09:57 AM
AbandonedBronco's Avatar
AbandonedBronco AbandonedBronco is offline
AbandonedBronco has a great reputation on FTE.AbandonedBronco has a great reputation on FTE.AbandonedBronco has a great reputation on FTE.AbandonedBronco has a great reputation on FTE.AbandonedBronco has a great reputation on FTE.
That shop is either: A) Completely ignorant or B) A bunch of scam artists.
My Chrysler LeBaron had to have been thee most difficult heater core replacement I've ever known. The entire dash had to come out. The steering wheel had to be disconnected and dropped. Center console and shifter had to be removed. The visors had to be removed! (Visors were covering A pillar panels, which were covering the side panels, which were covering the dash screws, etc, etc.)
A shop wanted $600 - $700 to do it. I don't blame them. It took me 8 hours in a professional shop to do it myself.
My Bronco.... It took me 30 minutes and a wrench.
You remove the glove box. Undo the bolts holding the heater box to the outside firewall. Remove heater core, put in new heater core. Tighten bolts back down. Replace glove box.
If someone's charging you $900 to do that.....
Heater Core Neede Gamc Cooling, Heating, Ventilation & A/C 0 10-19-2016 02:37 PM
heater core 79fordf250pickup 1987 - 1996 F150 & Larger F-Series Trucks 2 12-12-2012 02:03 PM
Heater Core Replacement JasonBrod 1997 - 2003 F150 5 10-04-2012 03:05 PM
High Output Heater Option Drac 1973 - 1979 F-100 & Larger F-Series Trucks 3 12-20-2011 11:15 PM
1985 f250 heater core f150rd 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 8 12-19-2011 08:55 AM
Tags
1978, 1992, 60, 87, box, bronco, core, escape, f250, ford, heater, removal, replace, replacement, smell, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
