clutch problems
You sure you don't have the clutch disc in backwards?
I see you have a 90. The 87-89's had the firewall flex problem.
One of the fixes was to install a small retainer bracket that bolted to the two
clutch master cylinder studs from inside the cab.
You can see if you have the firewall flex problem by pressing
down on the clutch pedal. Look under the hood and see if
the plate that the clutch master cylinder is mounted to pulls
away from the firewall.
Also the plastic bushings the clutch pedal shaft rotates on
wear out and can cause improper clutch pedal travel.
pdqford
16
07-24-2019 06:07 PM
2006powerstroke90
08-23-2014 08:27 PM
RavenR90
1983 - 2012 Ranger & B-Series
07-10-2014 10:32 PM
mfoxcontract
03-13-2007 10:07 PM
