No roll .................
2002 F-350 4x4 auto
Feels like the brakes are on , wont even roll down steep hills.
Just got the rears completley done last Friday.
Check fronts the look ok and have about 50% pad left.
On the rear we changed the pads , rotors and calipers.
Check E brake.
I drove it about 10 miles today then felt all the hubs / wheels , nothing was hot.
Its bad and i need the truck , does anyone have any ideas?
Check E brake.
Don't touch your calipers immediately after a drive, be very careful because they can get scortching hot but after driver around a bit stop and check all the calipers, make sure they feel about the same temp. If one is hotter than the other then you have a hanging caliper which could be either the pistons on the caliper or sliding pins.
If it is a caliper you can get new calipers at napa (piston side only) for 55 bucks.
I just replaced both my rear calipers, pistons side only.
Just replaced both sides on the back with everything new , calipers , rotors and pads.
Took it to a shop today.
Mechanic pulled all the wheels and checked everything out.
Said nothing was wrong with it , I left his shop and pulled out on the street and stepped on it.
I almost got ran over it was just like the e brake was on.
It used to be I could spin the tires on dry pavment easily.
