Loose Steering in my F350. - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 11-21-2014, 02:00 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Steering and Suspension Guides
Print Wikipost
Old 05-18-2011, 06:18 PM
jf2oo6 jf2oo6 is offline
jf2oo6 is starting off with a positive reputation.
I have a 99 F350 with the 7.3 diesel. The truck has 245k on it. The problem I have is there is play in the steering wheel. I have to turn the wheel about an eighth of a turn in either direction to get the wheels to respond. So in other words I can turn the steering wheel from about 10 o'clock to 2 o'clock without the front wheels responding.
Can you guys please point me in the right direction as to what I should start looking at first? I will go tug on any parts of the steering shaft I can reach and see if theres any play, but I'm wondering if theres any adjustments I can make. I appreciate any help.
Old 05-18-2011, 06:20 PM
jc8825's Avatar
jc8825 jc8825 is offline
jc8825 is gaining momentum as a positive member of FTE.jc8825 is gaining momentum as a positive member of FTE.
You can try tightening the steering box. I haven't done it myself, but there is an hex key bolt on it. Don't make it too tight.
Old 05-18-2011, 08:24 PM
wizardsr's Avatar
wizardsr wizardsr is offline
wizardsr is gaining momentum as a positive member of FTE.wizardsr is gaining momentum as a positive member of FTE.
There's a lot of possibilities with that kind of mileage on the truck. Have someone rock the steering wheel back and forth while you watch for play in front end components under the truck.
Old 05-18-2011, 10:19 PM
Ok so I tried tightening the steering box one quarter turn, and that helped a little bit. I will try a little more tmrw. Kinda ran out of daylight today.
Old 05-20-2011, 12:39 AM
fbh31118's Avatar
fbh31118 fbh31118 is offline
fbh31118 is gaining momentum as a positive member of FTE.fbh31118 is gaining momentum as a positive member of FTE.
Go to this link.
http://www.ford-trucks.com/forums/10...-problems.html
This will cover most of what your describing. This one really helped me after I bought mine. Keep us up to date on what you find.
Old 05-20-2011, 10:18 AM
rotun's Avatar
rotun rotun is offline
Reads ***** rules!
rotun has a good reputation on FTE.rotun has a good reputation on FTE.
Also check the BIG nut on the pit-man arm, really helps to get it on jack stands, wheels off the ground, KOEO and have someone rock the steering wheel in the dead space. Position yourself so you can see the shaft going into the steering gear and the pit-man arm in your peripheral, if the shaft movement does not match the pit-man arm movement then you'll need to start with tightening the worm gear mesh, follow the posted instruction and don't go too tight or you will bind the gears and not be able to steer! If that checks ok, look at the pit-man arm and make sure the movement between the arm and the shaft it is on matches, if not, you will need to get the right size socket and re-torque, I do it from the drivers side wheel well with the tire off. Next thing to check would be drag link, tie rod ends, etc. Basically you are having someone move the steering wheel in the dead space while tracing the input from the steering wheel all the way to the wheels. You'll find it this way.
Old 12-29-2013, 10:46 AM
DrtyJack75 DrtyJack75 is offline
DrtyJack75 is starting off with a positive reputation.
Quote:
Thank You!! I just replaced my tie rod ends and connector link (or whatever its called) and there was a little play.....checked that pitman arm nut and BAM all better!!
How do I center the steering wheel? Metal twister 1999 - 2003 7.3L Power Stroke Diesel 5 12-04-2016 11:02 PM
Loose/Tight spots in steering Onebigtoy 1973 - 1979 F-100 & Larger F-Series Trucks 12 11-30-2016 02:04 PM
1989 F-250 Steering Question from a NewB Eric3501 1987 - 1996 F150 & Larger F-Series Trucks 9 02-11-2016 11:15 AM
Help Needed with Loose Steering Jager 1999 - 2003 7.3L Power Stroke Diesel 8 04-23-2010 10:44 AM
91 steering play armydad71 1987 - 1996 F150 & Larger F-Series Trucks 7 03-18-2009 07:40 AM
Tags
02, 04, 2001, 2008, 2011, 97, 99, column, f250, f350, ford, loose, play, steering, superduty, wheel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
