2005 F350 6.0 with Oil in the Coolant? - Ford Truck Enthusiasts Forums
Old 05-18-2011, 04:17 PM
Texas 6.0's Avatar
Texas 6.0 Texas 6.0 is offline
Texas 6.0 is starting off with a positive reputation.
Have a 2005 F350 with 130k, 6 months ago (at 112k) have the standard "cab off" 6.0 issues in which time the heads were pulled new ARP head stud with EGR delete kit. <?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
I have had a dark yellow substance in the coolant tank that when the truck cools down it sits on top of the coolant like oil. The mechanic that repaired the truck has not seen this and is not sure what could be causing it.<o></o>
<o></o>
Two main questions:<o></o>
1) I don’t even know what is getting in to the coolant?<o></o>
2) Every time I park the truck and get out, I smell Diesel BAD. But no leak anyware? <o></o>
<o></o>
Any help would be great.<o></o>
<o></o>
Thanks<o></o>
Old 05-18-2011, 07:17 PM
exiled's Avatar
exiled exiled is offline
exiled has a very good reputation on FTE.exiled has a very good reputation on FTE.exiled has a very good reputation on FTE.
Texas go start a thread in the 6.0l section and ask this question.
In what I've read oil in the degas bottle can be egr cooler leaking, you said that's deleted. Did he do it right? Oil cooler leaking. Blown head gaskets. You said you had arp studs installed. Did he reuse gaskets or messed up the new ones. I've read domething about some aftetmarket gaskets leaking. I cant remember why or anything. I hope you get it figured out.
Old 05-18-2011, 07:20 PM
powerstroke72's Avatar
powerstroke72 powerstroke72 is offline
powerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputation
Moved to correct forum.
Old 05-18-2011, 08:05 PM
BLADE35's Avatar
BLADE35 BLADE35 is online now
BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.
does the coolant smell like diesel fuel
it could be diesel in the coolant bottle
a cracked injector cup would cause this
they are replacable first time I heard this one
oil would be grey/black slug
hows the oil leval on the dipstick
welcome to FTE
Old 05-18-2011, 08:32 PM
Dieselpop Dieselpop is offline
Dieselpop is gaining momentum as a positive member of FTE.
X2 cups if you remove the degasing cap and it smells like fuel or does it look like gray goo oil cooler. after you find out you should get this to clean the system just before the repairs to get it clean.
http://www.fleetguard.com/pdfs/produ...LI33024-GB.pdf
pop
Old 05-18-2011, 08:35 PM
2006powerstroke90's Avatar
2006powerstroke90 2006powerstroke90 is offline
2006powerstroke90 has a great reputation on FTE.2006powerstroke90 has a great reputation on FTE.2006powerstroke90 has a great reputation on FTE.2006powerstroke90 has a great reputation on FTE.
I think your oil cooler failed....
dont drive it, just replace it, do a GOOD flush.
Old 05-18-2011, 08:38 PM
bismic's Avatar
bismic bismic is offline
bismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputation
As dieselpop said, oil in the coolant doesn't look black. It mixes with the water and emulsifies. Looks like a chocolate milk shake.
Diesel Technician Society
Also:
http://www.youtube.com/watch?v=hqwsT...eature=related
Old 05-18-2011, 08:42 PM
exiled's Avatar
I didn't catch the "yellow colored". I guess I just took it as oil in the degas bottle.
I'm going to look into the injector cup. I don't think I'll ever know enough about this engine. Lol.
Old 05-18-2011, 08:47 PM
BLADE35's Avatar
Thanks for the link to the pic bismic
he didnt say anything about choclate milkshake
I think its diesel in his coolant
Old 05-20-2011, 10:26 AM
Texas 6.0's Avatar
Thanks for the help. New to the forum.
Old 05-20-2011, 10:32 AM
Texas 6.0's Avatar
welcome to FTE
BLASD35
All the injector cups were replaced, the heads were checked out and reinstalled with all new gaskets(dont have the specks on parts replaced). The substance does smell like diesel. Have done oil changes since repair and oil does not show signs of any type of mixture.
Old 05-20-2011, 11:46 AM
BLADE35's Avatar
Quote:
Originally Posted by Texas 6.0 View Post
BLASD35
to me it just doesnt add up the mechanic said he didnt know what it was or what was causing it. And then you said he replaced all the injector cups. Injector cup replacment is not common at all. when did you find out he replaced the injector cups after you mentioned the problem to him and said something to him about diesel in the coolant ??
maybe he replaced all the injector o-rings I can see him doing that before replacing all the injector cups
Old 05-20-2011, 11:50 AM
rdunagan's Avatar
rdunagan rdunagan is offline
rdunagan is gaining momentum as a positive member of FTE.rdunagan is gaining momentum as a positive member of FTE.
i didnt think you could replace injector cups because i had an injector cup that cracked i had to get a whole new head
Old 05-20-2011, 12:09 PM
BLADE35's Avatar
injector sleeves and glow plug sleeves are replacable it take a special tool
look in the 6.0 bible under unique service procedures
But it could also have a crack in the head that would cause this
Old 05-20-2011, 02:17 PM
Texas 6.0's Avatar
Back in October 2010 the mechanic pulled the heads due to the fuel puking out the front of the motor. He said that i had two injector sleeves/cups that were cracked, and a failed EGR he replaced them all. As per him the heads were checked out and were not cracked and reinstalled them on the truck.
This current problem reared its uguly head 2-3 months after all work was completed.
FYI-The mechanic i used is an ex dealership head diesel guy that cuurntly teaches a class on diesel repair at the local collage.
From what i have been told if i had a cracked head, leaking head gasket, or a cracked injector sleeve this thing would'nt run 10 miles with out puking fuel all over the place.
2004 F250 6.0 Help needed dk4182 6.0L Power Stroke Diesel 4 05-19-2016 11:30 PM
2011 F250 4x4 - NOT! Rayil 1999 to 2016 Super Duty 82 08-14-2012 08:45 PM
2005 Bad Sway Problem? Texas 6.0 6.0L Power Stroke Diesel 18 02-19-2012 10:14 PM
6.0 2005 350 PSD start off bogging lack of power Mike821 6.0L Power Stroke Diesel 53 02-16-2011 11:20 AM
Wierd cylcling sound when towing up grade? MaxOut 6.0L Power Stroke Diesel 39 10-19-2009 09:12 AM
Tags
05, 2005, 350, 60, 6ol, cab, coolant, cooler, diesel, f350, ford, fuel, hard, location, oil, problem, pull
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
