4.56 gears in my V-10 - Ford Truck Enthusiasts Forums
Old 05-18-2011, 02:30 PM
Mr-Pipeline's Avatar
Mr-Pipeline Mr-Pipeline is offline
Mr-Pipeline has a good reputation on FTE.Mr-Pipeline has a good reputation on FTE.
Guys, I picked up my V-10 after having my 4.56 <?xml:namespace prefix = st1 ns = "urn:schemas-microsoft-com</st1:State>Yukon gears installed replacing my stock 3.73, with 285/75/16 tires, at a local shop. I donít have any pictures of the work being done, however I did snap a few pictures of the parts and the new differential cover after everything was buttoned up, Iíll post tonight. I purchased everything from Randyís Ring and PinionÖthey seemed to be the most knowledgeable and customer oriented. I called a few others parts suppliers but didnít get a warm fuzzy from any of them. One of the issues that RRP was very helpful on identifying what clutch pack I needed to rebuild my limited slip differential. Once we narrowed it down to two optionsÖthey sent one and committed to overnight the other pack if it was incorrect, they/we guess correctly. While it was in the shop I contacted Mike with 5-Star Tuning to get updated tunes to accommodate the new gear ratio. As always, they were quick to respond and provided the new/updated tunes, great service!
I donít have a lot of feedback to share as Iíve only driven it 3 times for a total of 20 miles. However, the increased torque is very noticeable! I really like the way it holds the RPM after it shifts and immediately starts pulling the next gear. At highway speed my RPM are running 2500 at 70 mph. This is an increase of approximately 500 RPM when compared to the 3.73 gears. I really like the way the truck runs at this RPM, it should allow me to tow in O/D without much trouble. Iím planning to tow on Memorial weekend to T<st1:City w:st="on">aos</st1:City> <st1:State w:st="on">New Mexico...</st1:State>that should be a good test! Iíll get a few pictures up later tonight.
Old 05-18-2011, 03:13 PM
dkf's Avatar
dkf dkf is offline
dkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to behold
What did the gears and install run you?
Old 05-18-2011, 03:28 PM
Quote:
I didn't cut any corners...Master rebuild kit for both front and rear, gears, and clutch pack for the LS, 1,150 bucks. 7 quarts of Mobil 1 oil, 100 bucks, New aluminum diff cover w/bolts 90 bucks, Installation of all the goodies 800 bucks. Total 2,140 dollars.
Some shops say it's okay to reuse the front barrings and shims to reduce costs. I didn't want to take any chances, the previous owner didn't perform much maintenance on anything.
Old 05-19-2011, 08:05 AM
Krewat's Avatar
Krewat Krewat is online now
Krewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputation
It will be interesting to hear how it works out - especially gas mileage.
I've often thought of doing this myself. It would be a FUN upgrade.
Someday... But then, I'm hoping to find a Dana 60 front-end to rebuild completely ...
Old 05-19-2011, 08:26 AM
grec-o-face's Avatar
grec-o-face grec-o-face is offline
grec-o-face has a great reputation on FTE.grec-o-face has a great reputation on FTE.grec-o-face has a great reputation on FTE.grec-o-face has a great reputation on FTE.
Mr P,
That's awesome!! I've been wanting to do the same for some time now - just not financially ready. I'm very interested to hear feedback as you provide it.
...Oh, and now you get to update your sig!
Old 05-19-2011, 10:06 AM
dkf's Avatar
dkf dkf is offline
Pricing wasn't too bad. If I'd do it my pricing would be around a grand more, no way the stock diffs are getting put back.
Old 05-19-2011, 11:31 AM
Krewat's Avatar
And for me, the pricing would be even lower. I reuse bearings after inspecting them. I look at it this way: If they survive what I already put them through, why risk replacing with an unproven bearing? If the unit was good before, they will be good afterwards.
The one thing I would do upfront before even taking them apart is make sure I have replacement small pinion bearings just in case. Every time I've pulled a gear set apart, the small pinion bearing is usually black. That goes for all sorts of different manufacturers, not just Ford. Of course, Ford doesn't actually MAKE the diffs for these things, but it seems that Dana, Ford, whatever, the small pinion bearing never seems to be the same brand as the rest of the unit - which is usually Timken. And that off-brand bearing is usually showing signs of wear, even with less than 50K miles on them.
Anyway, <rant off>
Old 05-19-2011, 03:13 PM
mwsF250 mwsF250 is offline
mwsF250 has a great reputation on FTE.mwsF250 has a great reputation on FTE.mwsF250 has a great reputation on FTE.mwsF250 has a great reputation on FTE.mwsF250 has a great reputation on FTE.
If the towing results are a impressive as I fear, please keep it to yourself, K?
I had finally convinced myself that my 4.30's are just fine and I don't "need" 4.88's........
Old 05-19-2011, 05:41 PM
Quote:
Originally Posted by Mr-Pipeline View Post
Guys, I picked up my V-10 after having my 4.56 <?xml:namespace prefix = st1 ns = "urn:schemas-microsoft-com</st1:State>Yukon gears installed replacing my stock 3.73, with 285/75/16 tires, at a local shop. I don’t have any pictures of the work being done, however I did snap a few pictures of the parts and the new differential cover after everything was buttoned up, I’ll post tonight. I purchased everything from Randy’s Ring and Pinion…they seemed to be the most knowledgeable and customer oriented. I called a few others parts suppliers but didn’t get a warm fuzzy from any of them. One of the issues that RRP was very helpful on identifying what clutch pack I needed to rebuild my limited slip differential. Once we narrowed it down to two options…they sent one and committed to overnight the other pack if it was incorrect, they/we guess correctly. While it was in the shop I contacted Mike with 5-Star Tuning to get updated tunes to accommodate the new gear ratio. As always, they were quick to respond and provided the new/updated tunes, great service!
I don’t have a lot of feedback to share as I’ve only driven it 3 times for a total of 20 miles. However, the increased torque is very noticeable! I really like the way it holds the RPM after it shifts and immediately starts pulling the next gear. At highway speed my RPM are running 2500 at 70 mph. This is an increase of approximately 500 RPM when compared to the 3.73 gears. I really like the way the truck runs at this RPM, it should allow me to tow in O/D without much trouble. I’m planning to tow on Memorial weekend to T<st1:City w:st="on">aos</st1:City> <st1:State w:st="on">New Mexico...</st1:State>that should be a good test! I’ll get a few pictures up later tonight.
Here's some pictures I promised...not much to look at hopefully it will help someone in the future.
Before work began
After everything was completed
Clutch pack for rear limited slip
Master re-build kit
Old 05-19-2011, 05:56 PM
dkf's Avatar
dkf dkf is offline
Holy rusty undercarrige batman. I take it you bought the truck up north.
Yukon does a fine job packing everything. I'd be interested in hearing if those Yukon gears (for the 10.5") are noisier than the OE Ford gears.(Once they are broken in of course) I've heard the Ford gears are quieter.
Old 05-19-2011, 06:50 PM
It's been in Texas it's entire life...however the first 9 years it was in Beaumont, very humid. The picture makes it look worse then it is! The center piece is an add-on gooseneck hitch. I'll make sure I include a noise update following my trip to Taos NM.
Old 05-20-2011, 07:11 AM
Johnny Langton's Avatar
Johnny Langton Johnny Langton is offline
Johnny Langton has a great reputation on FTE.Johnny Langton has a great reputation on FTE.Johnny Langton has a great reputation on FTE.Johnny Langton has a great reputation on FTE.Johnny Langton has a great reputation on FTE.Johnny Langton has a great reputation on FTE.
That truck saw some beach/salt water without getting washed good afterward sometime in it's life. I work in Beaumont everyday, and live 40 miles north of Beaumont, and none of our vehicles look anything like that.
I thought the same thing as dkf did when I saw the pics.
JL
Old 05-20-2011, 11:47 AM
JL
It's very possible...I'm not sure if you remember what the inside of the engine looked like, maybe never had an oil change since new. It looks ugly but it's only surface rust the frame and everything is solid. If your north of Beaumont you might have seen this truck. It was registered/sold in Lumberton since new. Heck it could have seen high water during the storms that hit that area several time over the years?
Old 05-20-2011, 12:53 PM
I drive through Lumberton every day on the way home. It's miserable driving through that little 2 lane bottleneck.
The high water would be no different than the rainfall we see every year and driving in the rain. That's gotta be prolonged exposure to water or salt water from the beach.
JL
Old 05-20-2011, 01:51 PM
Falconscheduler Falconscheduler is offline
Falconscheduler is starting off with a positive reputation.
I'm sure you know this but I didn't notice it mentioned so I thought I'd throw my 2 pennies in as gears are a big investment....Make sure you let your new gear set break in before towing. I have an F-150 that I put 4.56's in and also a good friend of mine with a V-10 Superduty that put 4.56's in his...we both ran them at least 500 miles as recomended not only by the gear manufacturer but the mechanics who did our gear swaps. I believe even RR & pinnion recommends short trips for the first 500 to let gears heat and cool to properly set. You will love how it tows, believe me! Enjoy!
1966 Ford F250 - Rear End Gear Change rick0516 1961 - 1966 F-100 & Larger F-Series Trucks 7 03-09-2016 07:22 PM
5.4L Super Duty 20mpg @ 70mph Jasonec83 1999 to 2016 Super Duty 38 06-12-2011 04:23 PM
99 Expedition Overheating - Afghanistan pzmotorsports 1997-2006 Expedition & Navigator 11 07-24-2009 09:39 PM
Update pending CA diesel retrofit law (w/links) Karl Aube General Diesel Discussion 17 05-07-2009 02:35 PM
Mason-Dixon TDC Diesel Drag & Dyno Day Aug. 11, 2007 Dockboy Events & Happenings 8 07-23-2007 10:32 PM
Tags
06, 1987, 2857516, 456, cost, duty, f250, f350, gears, pattern, ranger, super, tires, towing, v10
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
