You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
Anyone know of a good pyrometer that will work on these new ecoboost engines? I'd like to have one so I know before I destroy my engine accidentally. Any suggestions? Thanks guys.
I get it after doing a search. My father in law has one for his diesel I guess with the turbos it would be nice esspecially after towing. I wouldn't mind one either. I wonder if there is a ford one available. On the screen where it shows Trans temp. There is a blank menu it would be nice to add one there but I am not sure if that is possible?
__________________ 2011 F150 Xlt Crew Cab 4x4, Sterling Gray, 3.5L EcoBoost, Max Tow, Back up camera and tailgate steps
EGT's will kill any engine with a turbo. Having a pyrometer pre-turbo will better inform you if your EGT's are getting too high so you can pull over to the side of the road and let it cool off.
What I'm worried about is what the 6.0L and 6.4L PowerStrokes were having with the EGR. There would be an overpresurization that would cause coolant to leak into the engine and cause damage to your engine before you got the CEL. Am I being too paranoid?
Too much fuel in a diesel increases EGT. Too much in a gas cools it, and eventually puts out the fire altogether, as a too rich mixture won't burn. Lean in gas will heat things up, but again, eventually you get a miss and you will get a CEL with rich or lean, as the oxygen sensors are always sniffing that out.
The owner's manual should advise on when you would get an CEL and why, and iirc, the flashing CEL means to shut it off asap.
