How to jack truck?
#46
What about using ramps for jobs that don't entail taking the wheels off? Something like this?
Petersen Tru-Cut Deluxe Ramps — Pair, 10,000-Lb. G.V.W. Capacity, Model# 30-2310 | Car + Truck Ramps | Northern Tool + Equipment
Per my earlier note, I purchased this. Got to try them out today - they failed. Both inclines partially collapsed under the weight of the front axle (~4720 lbs) and the cross braces on one folded. There was no way I was getting under the truck with these - so that was the end of my Saturday work plans. I have contacted Northern Tool to get a refund.
#47
2 Ton Cross Beam Adapter fits Floor Jack 4000 lb: LD-4002 Toolz Unlimited
... is the way to go. But I can not find one rated for more than 2 tons and the front axle has 4700+ pounds on it (it's a diesel). As the engineer in me says "thou shall not overload your equipment", anyone know of a 3+ ton rated cross beam adapter, and a compatible floor jack? Suggestions for jack stands would be appreciated too, ones with a nice wide stable base.
Thanks!
Steve
#49
unlucky2.1_7.3PSD
07-19-2016 02:14 PM
calvinone67
01-20-2010 08:33 PM
