How do I kill the seatbelt chime? - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 05-18-2011, 06:58 AM
jbarefoot's Avatar
jbarefoot jbarefoot is offline
jbarefoot is starting off with a positive reputation.
The po of my 99 SD installed custom seats which I have taken out and replaced with 04 seats. The original wire harness is gone but the chime keeps going off. Can I kill this under the dash, I can't seem to locate the little speaker anywhere.
Old 05-18-2011, 01:20 PM
jc8825's Avatar
jc8825 jc8825 is offline
jc8825 is gaining momentum as a positive member of FTE.jc8825 is gaining momentum as a positive member of FTE.
The speaker is in the gauge cluster which you cannot modify. The owner's manual gives you step by step directions on how to deactivate the "Belt Minder". What do you mean that the wire harness is not there? The PO cut the wires off?
Old 05-18-2011, 03:22 PM
ExplorHer1369's Avatar
ExplorHer1369 ExplorHer1369 is offline
ExplorHer1369 is starting off with a positive reputation.
Quote:
Quoted for truth.
Old 05-19-2011, 05:56 AM
jbarefoot's Avatar
Well I now have 2004 front seats , the originals are long gone and all thats left is a wire sticking up out of the floor. Anything I've read on this says that you need the seat hooked up to disable the alarm.
Old 05-19-2011, 07:49 AM
dkf's Avatar
dkf dkf is offline
dkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to behold
Do you have the stock seat belts and the latches in the truck?
My 04' has 2 plugs, both of which look like they go towards the female belt latch beside the seat. There are two plugs, one plug is gray, one plug is yellow. Both the wires with the yellow and gray connectors come up from one wiring harness from underthe floor and plug into the corresponding wires at the bottom of the seat which look like they go to the seat belt latch as I said earlier.
To disable my seatbelt minder I unplugged the gray connector only. I'm not recommending you unplug the gray connector just saying what I did and what my dad did on our trucks. I didn't know about the the procedure at the time. I'm pretty sure the belt minder alarm is integrated with the door ajar alarm.
Heres a pic
annoying chime firhead 1999 to 2016 Super Duty 6 09-22-2016 03:36 PM
Chime Hanlon50 2009 - 2014 F150 3 09-15-2013 08:30 PM
finally killed the door chime 86scotty 1968-2013 Full Size Vans 5 09-04-2011 03:15 PM
02 F250 Door Chime elimination texczech 1999 to 2016 Super Duty 0 07-20-2011 08:52 AM
Seatbelt warning chime GMtoFord 2004 - 2008 F150 10 11-19-2004 09:16 AM
Tags
2010, 550, belt, chime, code, elimination, f250, f450, f550, flex, ford, fuse, seat, seatbelt, speaker, ths, transit
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
