How do I convert from external to internal regulated alternator - Ford Truck Enthusiasts Forums
Old 05-18-2011, 01:55 AM
51chris 51chris is offline
51chris is starting off with a positive reputation.
I just put a 351M in to a 1979 bronco I got with no motor. The motor has a intenaly regulated alternator on it the the bronco was externally regulated so what I'm wondering is how do I convert to internally regulated. I already have a new plug I got to day just need know were the wires go and wich ones to eliminate
thanks for any help
Old 05-19-2011, 01:06 AM
Franklin2's Avatar
Franklin2 Franklin2 is online now
Franklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant future
A 351m never came with a internally regulated alternator(it's too old) so be careful. I am going to assume someone swapped it onto the engine you got.
Next question. What type of internally regulated alternator is it? GM, Ford, aftermarket?
Basically what you will need to do is find the trigger wire/terminal for the alternator you have. Most alternators need a wire from the keyswitch to bring them online to charge, and offline so they don't run the battery down with the key off. This wire on your bronco will be the green/red wire on the original regulator. It will be located on the "s" terminal or the "i" terminal of the regulator, depending on how it was equipped from the factory. And then of course you need to hook up the large output wire to the bat +, and some had a feedback wire also.
Old 05-19-2011, 10:45 AM
It is a ford alternator so I hooked the green and red wire to stator termanal and hooked white and black wire to feild termanal and output to + and no luck it didn't work the only one I didn't touch is the yellow wire with the capistor or what ever it is the one with the two yellow wires in the same teminal they just go to postive so mybe that has to go some were I will mess around a bit more if still nothing I'll go to a 3g I had stator & feild crossed at first so maby I fryed the alternator
Old 05-19-2011, 08:06 PM
Franklin2's Avatar
You have a regular stock Ford alternator it sounds like. I don't know why you said you had an internal regulator alternator. Here's how to hook it up WITH a external regulator for a Ford. If you do not have a electric choke, the stator terminal has no wire going to it on the alternator.
Old 05-20-2011, 11:47 AM
Just wanted to covert to internally regulated because that's what I had but it's on hold because I'm off to rokonvill saschawin for a few weeks to work then I'm doing a 3g when I get back we got about 8 lights on it a winch and a decent size sterio system so I'm sure we can use the extra power
1978 460 external to internal regulated alternator question three.on.the.tree 1973 - 1979 F-100 & Larger F-Series Trucks 8 02-07-2016 11:24 PM
Convert External Regulator to Internal on 1968 F100 ajbremer 1967 - 1972 F-100 & Larger F-Series Trucks 13 07-28-2015 07:24 PM
1 Wire Alternator.... 77 Bronco 1966 - 1977 Early Broncos 3 01-17-2015 12:41 AM
Alternator with external regulator Hansolo99 Ranchero & 1961 - 1967 Econoline 4 05-19-2014 09:59 AM
79 stock alternator i-w 1973 - 1979 F-100 & Larger F-Series Trucks 4 08-05-2011 10:31 PM
Tags
2001, alternator, altinator, altornator, convert, external, externally, f150, ford, internal, internally, make, regulat, regulated, regulator, requlator
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
