Replace Slave Cylinder 2003 Ford F250 - Ford Truck Enthusiasts Forums
Old 05-17-2011, 05:13 PM
fixitman405 fixitman405 is offline
fixitman405 is starting off with a positive reputation.
Question Replace Slave Cylinder 2003 Ford F250
How do you replace a slave cylinder on a 2003 Ford F250 6.0 Diesel 4-Wheel drive / turbo? Specifically need to know how to remove the existing unit in order to install the new one. Thx!
Old 05-18-2011, 05:23 AM
Lazy K Lazy K is offline
Lazy K is a name known to allLazy K is a name known to allLazy K is a name known to allLazy K is a name known to allLazy K is a name known to allLazy K is a name known to all
As far as I know you rotate it a quarter of a turn and withdraw it.
Glow Plug #5 would that Be Cylinder #5? Keny1 6.0L Power Stroke Diesel 1 10-25-2013 05:28 PM
Value Question jayzad 1973 - 1979 F-100 & Larger F-Series Trucks 0 02-27-2013 07:11 AM
1999 F250 Slave Cylinder issue FiftyCalUSMC 1999 to 2016 Super Duty 3 11-14-2012 11:54 AM
clutch slave cylinder o-ring bigtread 1987 - 1996 F150 & Larger F-Series Trucks 3 05-20-2007 07:47 PM
Slave Cylinder on a 74 250 jenkinsj Brakes, Steering, Suspension, Tires, & Wheels 0 08-14-2005 10:16 AM
Tags
1996, 1999, 2000, 2003, 73, cylinder, diesel, diesiel, f250, ford, removal, replace, replacement, slave, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
