97 ranger heater core removal - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Old 05-16-2011, 10:31 PM
roushboy roushboy is offline
roushboy is starting off with a positive reputation.
does anybody have any info on how to remove the heater core housing so i can replace the blend door
Old 05-17-2011, 01:31 PM
powersmoked's Avatar
powersmoked powersmoked is offline
powersmoked is gaining momentum as a positive member of FTE.
Quote:
remove the dashboard and then swap out the blend door...........also check this site out......... Auto replacement part, blend door fix, Heat, AC replacement parts
Old 05-18-2011, 02:59 PM
nd925 nd925 is offline
nd925 is starting off with a positive reputation.
Used these instructions on my 98 and they worked great.
http://www.ford-trucks.com/forums/15...placement.html
Found in the Technical Information sticky.
Best of luck
easiest way to remove dash for heater core 93 mix 'n match 1997 - 2003 F150 16 01-10-2017 12:03 AM
1988 heater core replacement f-350 case310350 1987 - 1996 F150 & Larger F-Series Trucks 9 05-09-2012 12:48 AM
02 F-150 Heater Core Jterr 1997 - 2003 F150 0 08-10-2011 09:14 AM
heater core hose removal??? zed326 1997-2006 Expedition & Navigator 3 01-28-2009 05:14 PM
help removing heater core on 1990 F150 Kreedance 1987 - 1996 F150 & Larger F-Series Trucks 5 12-13-2008 01:45 PM
Tags
1997, 1999, 97, coil, core, diagram, ford, heater, install, mazda, ranger, remove, replace, replacement, series
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
