DP Tuner messing with radio reception
I have noticed that my radio reception has been very poor latley and have not been able to figure out why. I read on another forum that somebody with a super duty had the same problem and blamed it on his DP Tuner. I have the DP as well so I went outside and tested the theory. I turned the key backwards so the tuner did not activate and the reception was clear as can be. I turned the key forward so the tuner would activate and it was very fuzzy again. Has anyone else delt with this problem or know an easy fix? I read about Ferrite Bearings but do not know much about them or how they work. Do you think this will fix my problem?
i recently installed a dp tuner and have not had a problem like what your describing at all.. no static at anytime.. unless poor reception...goes without saying..
i would email james @ james@dp-tuner.com, i have emailed him a few times and he is always quick with the responses and very helpful
Good luck
Good luck
red 1997 powerstroke
17
04-30-2012 07:25 AM
20
11-18-2011 05:36 PM
glankerglanker
09-17-2008 01:30 AM
