99 f350 7.3l 4x4 rearend diff fluid
i have a 99 ford f350 lariat 4x4 i have to change the front seal on my rear diff. i know what kind of gear oil to use the 75w140 synth i plan on using the royal purple my question is how much do i need i want to completly change the fluid. my other question is what rearend do i have there is a tag on the rearend that reads 3 S 409 E
L73 10 5 9F24
any help will be greatly appriated thanks.
L73 10 5 9F24
It is not nearly that much.
Assuming this F350 is a SRW model, you have a Ford Sterling 10.5" rear diff. Fluid capacity is 3.3L. You will need to buy 4 quarts and will have a bit left over.
As Brian said, it is limited slip. So make sure the oil has friction modifier built in. I'm pretty sure RP does, but check the bottle. Mobil 1 is also a good choice. Synthetic is required.
dyoungen
02-21-2012 02:58 PM
bubba_v2008
05-16-2011 11:32 PM
jimbo beam
109
07-01-2007 05:21 PM
